mrbeige 0 Posted February 13, 2008 Very quick question. Will a Magnex fitted to a late valver fit an early one? I know that the hangers are different, but will it fit? Quote Share this post Link to post Share on other sites
mic_VR 3 Posted February 13, 2008 I believe the exhaust travels the same route on all Corrado's and you should be able to buy later hanger brackets direct from VAG. They just bolt onto the floor plan....... but I'm sure someone will confirm Do it! :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 13, 2008 I believe the exhaust travels the same route on all Corrado's and you should be able to buy later hanger brackets direct from VAG. They just bolt onto the floor plan....... but I'm sure someone will confirm Do it! :lol: Well, if you can the hangers from VW, then I might have to get them :) Quote Share this post Link to post Share on other sites
flusted 0 Posted February 14, 2008 the 2l has a cat the 1.8 hasnt Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 14, 2008 the 2l has a cat the 1.8 hasnt Indeed, but the exuast is a CAT back system, and doesn't the 1.8 have a longer manifold and downpipe? Quote Share this post Link to post Share on other sites
blue95 0 Posted February 14, 2008 the 2l has a cat the 1.8 hasnt Indeed, but the exuast is a CAT back system, and doesn't the 1.8 have a longer manifold and downpipe? Yep true. I believe the diameter of the pipes is the same. As for rubber hangers you can get universal ones so that they can hang off/on a bar or a hook type hanger. Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted February 14, 2008 The downpipe on the 1.8 runs into the front silencer which sits where the cat on a 2.0 would, so I reckon it would be do-able. Dunno if the mounting holes for the different hanging brackets are there in the floorpan or not though. A few self tappers should hold it up? :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 14, 2008 It's sounding better every post! :D I'll have a look under the 2.0 at the weekend and see if I can get the hangers off that and see if they will fit to the 1.8. Quote Share this post Link to post Share on other sites
Toad 0 Posted February 14, 2008 They should just unbolt off the crumble and go straight onto Gooney, then the pipe will fit nice and securely. :) The pipe legnths from the cat on a 2l or the downpipe from a 1.8 seem exactly the same. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 14, 2008 They should just unbolt off the crumble and go straight onto Gooney, then the pipe will fit nice and securely. :) The pipe legnths from the cat on a 2l or the downpipe from a 1.8 seem exactly the same. Sweeeeet, might have to try and sort that this weekend, along with stripping the Badcrumble completely :doc: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted February 14, 2008 No Definately won't so you'll just have to sell it to me! :lol: Seriously though if it doesn't I'm on First dibs for the exhaust! I need to lose the "quality" Walker Back-box! Quote Share this post Link to post Share on other sites
