vwdeviant 0 Posted March 19, 2009 Hi Guys, ordering up my new topmounts but the local dealers are a bit confused about what to order... On ETKA shows a range of parts (from the top) Nut Washer Nut Cup Bearing (Rubber) Washer Nut Sleeve Bearing (Rubber-Large) "Top Hat" So the question is what do I need to order to add to my Coilover kit?? Help please! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 19, 2009 you should only need the rubber bits. I bought everything on the diagram, i renewed all the washers and spacers anyway but really was no point. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted March 19, 2009 Attached is the fax they sent Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 19, 2009 you should be able to reuse most of the metal parts as they don't seem to wear, i guess mine had been on car since new and they looked just like the new stuff still. anything from no. 13 down will be replaced by the coilover unit. The rest is just spacers and nuts Quote Share this post Link to post Share on other sites
blue95 0 Posted March 19, 2009 only the rubber bits need to be replaced. £4.95 for both sides (FEBI/Bilstein) of vwspares http://www.vwspares.co.uk/product_info. ... cts_id=502 S Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 19, 2009 Always replace number 7 and number 10 (the bumpstop) and get a new bolt for the bottom. You only need to worry about the metal washers if you're changing from Koni's etc back to standard as they use bigger versions for the larger thread... Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted March 19, 2009 :salute: Cheers Dudes... ordered VR spec ones (same as Late 16v? Seemed to be on ETKA) It's a KW-1 kit so all should be plain sailing! Just wanted to get the bump-stops done whilst they were out, made sense... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 19, 2009 7 & 10 will/should come with the coilovers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 19, 2009 Sorry! - didn't realise you were fitting coilovers! Just get the topmounts and the bolts - same on all corrado's Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted March 20, 2009 OK rather than start "Another thread" KW-1's will be on this weekend, so I'm wondering just how much do they Settle by after running them for a bit? Have to take into consideration 3 speed humps in our road, (one of which is big enough to be recently filmed with a bunch of celebs climing it for Comic Relief!) :mad2: Suspension's being done at a mates workshop some 60 miles away so I have that trip back round the M25 to get the coilies to "settle down" and if I set them at it's current height and they drop say 10mm I'm going to bugger the chin spoiler up (just "kisses" 2 of them ATM) So any advice would be much appreciated... :salute: Quote Share this post Link to post Share on other sites
The_Dude 0 Posted March 20, 2009 er, think mine settled about an inch or so over the course of a few days. mine's not a daily tho so i couldn't really tell. parked it up and when i came back a few days later it was eating wheel! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 20, 2009 i see that a car will settle down after your taken it off the jack etc and had a quick spin, but i don't see how or why it should drop anymore after that? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 20, 2009 When we fitted the coilies to the Golf VR the front settled LOADS more than the rears, in fact prolly around 2 inches on the front and an inch on the back...whether that will apply to the lighter valver engine I don't know... Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted March 23, 2009 i dont think the springs settle as such- just the internal seals etc inside the dampers free up slightly so theres less "sticktion" inside the damper tube, so the weight of the car will be held up to an extent by the extra friction of the damper. Over a few days/weeks the seals bed in,friction reduces so the car will sit lower over the shocks. its just like piston rings etc bedding in i guess, engines get "freer" over time Quote Share this post Link to post Share on other sites
corozin 0 Posted March 26, 2009 You should really order new bearings with the top mounts. For the price involved it's stupid not to. All the other parts you carry over. The settle in time for good quality coilovers is around 1.5 metres. :shades: Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 26, 2009 i think the diagram is of the rear top mounts, so no bearings Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted April 4, 2009 My coilies settled by over 2cm in the first few weeks - roads in Oxford are poor, and it is my daily, so it was a pretty quick drop. :pale: Not a big deal for the rears, but the fronts became a problem. Ended up eating rubber and getting very bald treads! Since they were adjusted back up they've been very stable in height. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted April 5, 2009 Strangely the Valver with it's new KW's and VR top mounts all round has hardly settled and done over 300 miles now! :clap: So could drop the front another 15mm... Trip to get the alignment and camber checked and re-set next weekend. Quote Share this post Link to post Share on other sites
