raddo_tom 0 Posted December 16, 2009 How do I break into my corrado without smashing a window or screwdrivering the lock? My batt is flat on the G60 and I need to move it asap. It's delocked and the boot lock has siezed! (to my suprise) Any help mucho appreciated. Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted December 16, 2009 Its a struggle but you can pop the bonnet with the grill removed, I learned the hard way when not tightening the bonnet pull cable tight enough. I had not fitted the grill at that point so will probably involve destroying it, probs less hassle than a window or door lock though. Therefore not actually breaking in, so I posted it up! Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 Tried that. It's impossible :brickwall: Quote Share this post Link to post Share on other sites
herisites 0 Posted December 16, 2009 You can definitely open the bonnet from the outside, the passenger side is easy enough to pop by removing the grill and pulling the cable. The drivers side involves jacking the car up and getting your arm up with a big flat screwdriver to lever the mechanism and then it will pop open. It's not hard, just annoying! Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted December 16, 2009 ^^^^ Yeah I should have mentioned that. I used some long reach pliers/plumbers wrench. Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 oil cooler is in the way on the drivers side... Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 16, 2009 Can you reach up with two wires and put 12 volts onto your battery, awkward but then you could open the car on the fob.. Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 never thought of that! Is there a way to do it via the starter motor? as the batt is well hidden I thought i'd be like a mk2 golf. (window seal ruler job) Quote Share this post Link to post Share on other sites
Rob_B 0 Posted December 16, 2009 you can get a live wire onto the starter motor and the chassis, job done Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 on the wire from the starter? Or just on the starter in general? :scratch: Quote Share this post Link to post Share on other sites
rado-steve 0 Posted December 16, 2009 on the wire from the starter? Or just on the starter in general? :scratch: Positive wire onto the positive terminal on your starter motor and the negative onto the chassis somewhere! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 16, 2009 Hope you got it sorted Tom! Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 Me too! Need to get on with the strip down! :eek: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 16, 2009 This is the main reason i would never go delocked, im sure you get it sorted eventually Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted December 16, 2009 Looks cool though! lol. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 17, 2009 on the wire from the starter? Or just on the starter in general? :scratch: Positive wire onto the positive terminal on your starter motor and the negative onto the chassis somewhere![/quote:1ftdnsrs] Nice one!! Im going to have to do this too :lol: Quote Share this post Link to post Share on other sites
mistrall 0 Posted December 17, 2009 i had the same problem not long ago, ended up using a doorstop a thin but rigid stick and some fishing line - worked a treet but no use if you dont have pins! Quote Share this post Link to post Share on other sites
marmite monster 0 Posted December 17, 2009 This is the main reason i would never go delocked, im sure you get it sorted eventually another classic case of form over function :D Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 17, 2009 Yep looks good but as we can see here can cause probs!! :D Quote Share this post Link to post Share on other sites
The_Dude 0 Posted December 17, 2009 Yep looks good but as we can see here can cause probs!! :D Just make sure your boot lock works first. :grin: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 17, 2009 Me climbing through the boot = :epicfail: i can only just get in the back seats never mind throught the boot and the back seats to get to the door pull!! Quote Share this post Link to post Share on other sites
The_Dude 0 Posted December 17, 2009 You need one of those long rods with a hook used for opening high up school windows. :D Quote Share this post Link to post Share on other sites
Zam0ldac 0 Posted December 18, 2009 What size speakers would fit into the doors of my '94 raddo? Thx in advance and Happy Holidays to all ! Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted December 18, 2009 What size speakers would fit into the doors of my '94 raddo? Thx in advance and Happy Holidays to all ! I know it says Really random question in the title, but you have just taken it to another level :lol: On a serious note, do a search in the Ice and security section, I'm sure the answer will be there. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted December 18, 2009 use an inflate a wedge off of snap on, bout 40 quid, or a wedge of wood tapped lightly down the side of the door just enough to get some pincers on the door pin, and handle , works on most cars. Quote Share this post Link to post Share on other sites
