fendervg 33 Posted April 6, 2011 With the way petrol prices are, I'm wondering if anyone knows of a six speed conversion for the VR that would give an overdrive ration that would drop revs at 80-100 mph to around the 2000-25000 range ? Quote Share this post Link to post Share on other sites
dukest 0 Posted April 6, 2011 depends on your mileage really, but unless you're doing it yourself then its got to be at least a £750 job by the time you've bought a gearbox (eg 02M) a clutch, and worked out what other bits you're going to have to change before fitting it too. I guess it might pay back in a year if you did a lot of motorway miles though? Quote Share this post Link to post Share on other sites
Dox 23 Posted April 6, 2011 We've got a 2001 Golf GT TDi pd 115 (remapped to 140ish) at 80 MPH its doing 2200RPM - impractical for a N/A petrol engine I would say Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 6, 2011 We've got a 2001 Golf GT TDi pd 115 (remapped to 140ish) at 80 MPH its doing 2200RPM - impractical for a N/A petrol engine I would say And I have the same in a Corrado which is 25% lighter :-) 6 Spd would be nice on a VR but I reckon an LPG conversion is what you want... Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted April 6, 2011 I dunno, if you've up'd the power i don't see why it wouldn't toddle along at 70mph at 2500rpm no problem... swapping boxes though I think is a little difficult. However, according to this link here http://the-corrado.net/showthread.php?45367-Vr6-6-speed-02S-Possible you can swap the gearset and end plate out of an O2S box. might be worth thinking about if you can find a cheep OS2 box... ---------- Post added at 04:56 PM ---------- Previous post was at 04:54 PM ---------- you could also go down the route of a 5th gear change but i only know of the 5th gear swap for a 4 cylinder O2A box http://wiki.the-corrado.net/5th_gear_cog_change.html Quote Share this post Link to post Share on other sites
coullstar 0 Posted April 6, 2011 There is also the Gemini 6 speed kit but you would need to do a lot of miles to get your money back on that. Lower FD as well but then it affects all gears. Quote Share this post Link to post Share on other sites
dragon green 5 Posted April 6, 2011 Or purchase an O2a box from a diesel golf/Passat and transplant the gears and final drive into your box ! You now have a rebuilt box,and depending on what code box you have,a top speed potential of 172-196mph that equates to 80mph at below 3000rpm ! Quote Share this post Link to post Share on other sites
jamiehamy 0 Posted April 6, 2011 Having done nearly 2000miles across Europe since Saturday, I have never thought another gear was needed. If anything, a Schrick manifold to bring the peak torque down a bit would be perfect. The car/engine sits much nicer at 80ish/3500 than it does at 70, especially up hills. She charges up the steepest gradients at 80 in 5th, but anything less than 70 and she labours a bit too much for my liking. So, unless you bring the peak torque lower, I honestly don't think 6th speed will help much tbh. Oh, and yes, LPG is the way forward...lol. Not that I'm biased! Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 6, 2011 Hmm - at 80 mine sits around 3000 or a bit higher. The two "hands" sit pretty much at the same position. A Schrick mani/VSR would be nice, although I think I'd only go for the VSR for ease of service - and they are damn hard to find. Quote Share this post Link to post Share on other sites
