Graphite
Final push to clear my remaiining parts cache
Hi all,
Given I have moved the Corrado project on now I am am on a major mission to get rid of all the parts I have stashed up still.
As theres about 95 lines of parts in a spreadsheet I'll post the images of the spreadhseet for you to browse for the prices.
Everything is + shipping and I will post worldwide, alternatively parts can be collected from Retford, Nottinghamshire.
Not all the parts in the images are listed so if you can see it in the photo but its not on the list please ask. Please look at the list though, people asking for prices for parts on the list will not be entertained.
If someone would like to offer me an ammount for the lot then please PM me.
Parts available:
Non Sunroof headlining retrimmed in Black
Black floor carpet set
Black boot carpets 2x left 1x right
G60 clocks, white dials, ~105,000 miles
Grey under dash trays (all 3 parts)
Grey foot plates (left and right outers)
Grey clutch foot rest
Grey boot latch surround
Grey rear ash tray
Grey gear shift section tunnel trim
Black A pillars
Black A pillars (2nd set)
Black B pillars
Black C pillars
Black boot panel trim in black
Black inner sill trims in black
G60 digifant ECU
Early window switches x 8
Early heated rear window switches x 3
Early heated seat switch
Early sunroof switch x3
Early mirror adjustment switch x 2
Early fog switch x 4
Spoiler manual adjustment switch x 2
Early heater fan control switch
Early interior door release handle surrounds (1xL 1xR)
Early dash cigarette lighter x 2
Early dash genuine VW tape storage unit
Early heater slider control facias x 3 (one with white decals)
Early headlamp switch
Complete early stalk assemblies x 3
Early indicator stalk only
Blue windscreen wash bottle and pump
Spoiler control modules x 2
Window control modules x 2 P/N: 191 959 875
G60 blue vac sender for clocks
KR 16v ISV
Roof arial base
Bonnet release lever
Door corner triangles (internal) x 5
Door corner triangles (external, 1 x L, 1 x R) x 2
Interior door pull hanles/grab handles x 3
Interior ceiling light x 5
Rear seatbelt cover trims (on top of rear quarter cards) x 4
Interior door release levers x 4
Rear boot latch replated
Rear boot lid damper
Front seatbelt pivot covers in black x 2
Rear view mirror x 3
Full G60 OE boost hose set up (not including boost return)
New G60 coolant outlet with new genuine blue and black senders
G60 OE coolant hose set
G60 cam cover breater vent (square screw down type)
G60 OE rubber fuel hoses from fuel pipes to fuel reg/rail
G60 lower cam cover
G60 cam belt tin plate
G60 brake master cyliner
G60 bonnet stay x 2
G60/16v PAS bracket to block x 2
G60/16v PAS tension bracket re plated
Spoiler mechanism
Early outer dash vents (1xL 1xR)
Early dash centre insert
Early steering colum surround
Boot window trim sets in black x 2
Black seat runner trims x 10
Rear parcel shelf supports/speaker supports in black ( 2xL 1xR)
Early tank strap set powdercoated in black
G60 front strut brace powdercoated in black
Spoiler securing brace powdercoated in black
Standard G60 front anti-roll bar powdercoated in black
G60/16v front crossmember and retaining brackets powdercoated in black
G60/16v lower rad supports powdercoated in black (one a bit thin)
Early front bumper in white with bumper iron
G60 heatshield sets x 2
Early bonnet in white
Full OE g60 brake pipe setup
Right hand Window mechanisms x 2
G60 throttle body
G60 alternator
G60 serpentine belt idler wheel
New JMR braided charger oil feed and return pipes
G60 knock sensors x 2
Interior blower motor
OE windscreren wiper arms (both L and R)
OE rear wiper arms x2
G60 alternator top mounting bracket to cyl head
Parcel shelf support straps
G60 charger support bracket (smaller one for boost side not pulley side)
G60 front grill badge in white
16v badge OE brushed finish
G60 rear bagde OE brushed finish
G60 front engine mounting bracket powdercoated inblack x 2
G60 O/S rear beam mounting bracket powdercoated in black
G60 dizzy.
6503de411f3c99649e85d68e406930dd.jpgbdd4b6548d34f19a39e056e0b03e7305.jpg550f145e8bcc9a792850db927660567b.jpgad820bb510309b85edf223377dc3a5c3.jpge949656749a4f39a634e82fa6dbb5fe1.jpg44a08b8c696355475c04a08943e19f0e.jpg70fa8511a46d0c8f98e1590518552781.jpg04777f7490cb860b3d8cd97055574737.jpgcbe55f152c518953dd45c077e9dc35a0.jpg39e1538e8f95534be76d6c76d563d3be.jpg7911cf5443b87c3df21077074130da72.jpgf583ec993b89019675f25ab2775f91f2.jpg
Edited by Graphite
Great list graphite. I'll take a pair of the rear seat belt trims that fit at the back of the parcel shelf trims please. Also how much for the cassette holder
Cressa
Sent from my SM-G900F using Tapatalk
Cressa
Hi cressa,
I'll Pm you.
Thanks.
I'll take the other pair of rear seatbelt trim covers please, the wiper arms and one of the rear view mirrors, if it's the mirror is in good condition?
Edited by culshaw
I'll take the other pair of rear seatbelt trim covers please, the wiper arms and one of the rear view mirrors, if it's immaculate?
Sent from my Nexus 5X using Tapatalk
I'll pm you too mate.
I'll take a set of exhaust heat shields if not too pitted?, and the tailgate damper posted please mate.
Cheers!
Also does early tank straps mean 50l tank or 70? If it's 70 I'll take them too, mine are horrid
Could I have the parcel shelf support straps please?
Send me your details and I'll get some dosh to you soon
Thanks
Are the radiator supports 16v/G60 specific? Or would it fit a VR6? If it would I'd be very interested in the better one :)
I'm not in just now so can't check etka or similar but will try to find out if you are not sure
They are different unfortunately
Thanks
I'll
Pm you.
Would you be willing to post the brake lines? I guess they aren't going to be the easiest to package. Also interested in alternator if still available cheers.
I'll pm you.
Is the inner larger tailgate trim in great condition with no scuffs? Plus, do you have the little screw clips that hold it on? Plus, if no one else has had them, can I have the triangle seat belt top covers please.
Can I have the large plastic boot trim in this pic
Have you got the fixings that go with it ?
Price posted please
Price posted please
Yes you can, can you please PM me with a postage address so I can quote. Not 100% on the fixings, I would have to look.
Do you mean the one that covers the spoiler mechanism in the tailgate itself? If so I would say its in good condition, there are likely some minor scratches etc, its 20 years old! I'll PM you a more detailed picture.
If youre asking for the trangular covers that go on the belt guide thats on the B pillar then yes, they're still available.
Yes please to both. Are there any marks on rear shelf supports/are the screw brackets intact? Could I have some pics of any marks on them too please.
Many thanks
[ATTACH=CONFIG]87413[/ATTACH]
Hello mate,
I'm not sure, but I think that I'm seeing hand brake cover trim on the picture above.
If so, is it still available and do you able to posted to Sofia, Bulgaria.
Best regards,
Nikola
Hello mate,
Best regards,
Nikola
Yes you are seeing one in black I believe. Can you pm me your full postal address and I will give you a price posted.
Troy.
