Cressa 44 Posted April 10, 2020 My ignition lock was ridiculously stiff in trying to turn it. I was thinking I would have to replace it!!! So I sprayed it with some vw lock lube i had and the result was instant. A smooth turning lock Cost to me = Nothing Smile on my face, priceless 😁 That does not happen often with a Corrado Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 10, 2020 You’ve got to love a free easy fix. There often a lot more to it than a quick squirt will resolve. Quote Share this post Link to post Share on other sites
fendervg 30 Posted April 10, 2020 If in doubt, lube it! I picked up a litte bottle of VW lock spray a few years back - looks like a small trave deodorant or sanitiser - always make sure to do them before the Mr Frost arrives. Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 10, 2020 Once you’ve done your locks before Mr.Frost arrives, Then do all your opening seals with this Quote Share this post Link to post Share on other sites
Cressa 44 Posted April 10, 2020 11 minutes ago, dragon green said: Once you’ve done your locks before Mr.Frost arrives, Then do all your opening seals with this I've got the same stuff and even use it on my window and door seals in the house. Brilliant product Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 10, 2020 Good for around the sunroof seal too. Stops it sticking to the opening when not In use over winter and makes all rubber stuff look quite new again if applied in time. Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 10, 2020 And for good measure, here’s a pic of the lock lube Quote Share this post Link to post Share on other sites
Keyo 47 Posted April 10, 2020 Im getting some of this stuff, didnt no it even existed, is it ok to spray it into the ignition barrel, as mine sometimes sticks and cant even turn the wheel lock, well annoying. Quote Share this post Link to post Share on other sites
Keyo 47 Posted April 10, 2020 2 hours ago, dragon green said: Once you’ve done your locks before Mr.Frost arrives, Then do all your opening seals with this How does this help your seals, stops things stick to the rubber ? Does it also treat the rubber and back to black? Cheers. Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 10, 2020 It doesn’t turn them black, but what it does do,when you get a hard frost,your doors won’t be frozen shut !Even when it rains and freezes, you can still get in your car, Quote Share this post Link to post Share on other sites
Cressa 44 Posted April 10, 2020 2 hours ago, Keyo said: Im getting some of this stuff, didnt no it even existed, is it ok to spray it into the ignition barrel, as mine sometimes sticks and cant even turn the wheel lock, well annoying. Mine was like yours. Seems to be fine as the electrics are on a separate lower part that this just turns. Fantastic cure for me. And gummi pflege is just the stuff that miracles are made of. You dont know how, but it just does 😄 Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 10, 2020 2 hours ago, Keyo said: How does this help your seals, stops things stick to the rubber ? Does it also treat the rubber and back to black? Cheers. It seems to rejuvenate old rubber if not too far gone and makes it easier to clean so black shite stops coming off it. Miracle stuff Keyo Quote Share this post Link to post Share on other sites
fendervg 30 Posted April 10, 2020 Careful now lads - talking about lube and rubber.........nearly like the old days on here. Quote Share this post Link to post Share on other sites
Keyo 47 Posted April 10, 2020 Good to know guys. Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 10, 2020 Careful now lads - talking about lube and rubber.........nearly like the old days on here.Ooh Matron Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 10, 2020 Could be worse, could be Ham & Cheese....🤐 Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 10, 2020 Johnson’s baby oil works well with rubber Quote Share this post Link to post Share on other sites
fendervg 30 Posted April 10, 2020 Vulcanised or gum rubber? Quote Share this post Link to post Share on other sites
tonedef 8 Posted April 10, 2020 2 hours ago, seanl82 said: Could be worse, could be Ham & Cheese....🤐 Now that is a blast from the past! Quote Share this post Link to post Share on other sites
fendervg 30 Posted April 10, 2020 Now that is a blast from the past!Branston pickle anyone? Quote Share this post Link to post Share on other sites
