boost monkey 0 Posted November 7, 2008 To Do List Small things: Paint offside caliper and replace piston seals (see pic below) Clean out rear wheelarches, Order reel/s of copper brake line, Assemble shock absorbers (pre-requisite coil springs not here yet) Clean up rear beam brackets, fit new CM and RSP along with front engine mount, fit PAS lines and route through RSP, clean up and refit PAS pump, waxoyl front and rear hub stoneshields, attach front stoneshields, paint/prep front NS hub, Big things (not Westwood): Fit new brake lines with help from Pete_griff, Waxoyl front end (wishbones, cavity in rad support panel, etc) Attach rear beam, Assemble stub axles et al on rear beam, Get MOT. And teh pics: Will be painting my good OS caliper tomorrow and replacing the seals. But, is it ok to run a girling and a lucas caliper? How the arch started... Rear arch cleaning has commenced. Not amazingly easy with a brush and cloth, but it's not too bad. Cleaned the inside of the arch lip really well. Definitely do not want to have to get new ones welded in :nono: Chassis design leads to a nasty water trap up top in the arch. I guess it's not too bad as it's on top of the sealer after all. More pics as and when. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 8, 2008 OH yeah, started the car up yesterday for the first time in 2 weeks. Still got switch issues, but it ran up fine after missing a little to begin with. Left it to idle until the oil was at 66 and then shut it down. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 9, 2008 Cheers to everyone who helped with this issue, cookies and group hug to follow. Soaked the bolts in the good stuff and let to stand for 5 minutes. Next, attacked with the Erwin at 50% torque to avoid shearing. Voila. All 3 loosened up real nice, so I MC Hammer'd round the edge to mark the bracket out plus sprayed through the hole as a locator. Guess who :wave: Stencil seemed to work quite well, think i'll waxoyl the chassis under here after I sort that little patch out. and it's off. Had to snip the hardline going to the OSR bracket mount. This is routed under the heatshield UNDER the exhaust so having a small poolet trying to work out how i'll replace that one easily. Maybe drop the box off: it needs a new clamp on it anyways! Which one should I put back on? :bonk: Quote Share this post Link to post Share on other sites
coullstar 0 Posted November 9, 2008 Where are you doing your degree? I had a place on the first Masters in Motorsport Eng @ Cranfield but sadly I couldnt afford to do it. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 9, 2008 I'm at Oxford Brookes. I was going to change to the MEng but i'm not so sure now. The workload is quite high already and the teacher's aren't really helping at all! Quote Share this post Link to post Share on other sites
coullstar 0 Posted November 9, 2008 I never did a Masters but the best thing to do is look at future jobs and see if it will help you. The Masters for my Mech Eng degree was basically just the same amount of work as the BEng final year but spread over two years rather than one. Good work with the car by the way. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 9, 2008 Ah cool, yeah that's a good plan, I'm not sure how much weight employers put into it. Cheers! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 9, 2008 Did the carriers earlier today: Thought blocking up the bolt holes with Blu-Tac would be a good idea! Masking tape on the pin sliders. Think I found the culprit of the seized caliper - guide pin on the far right. Will need replacing! All sprayed up. Took aaaages+2 to dry though, still not sure why. Finished. I really hope these lucas carriers are ok with Girling calipers! They seem to line up...blu-tac was a mofo to get out too! Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted November 10, 2008 Finished. I really hope these lucas carriers are ok with Girling calipers! They seem to line up...blu-tac was a mofo to get out too! Did the paint solvent make the Blu-tac go all sticky :lol: :lol: :lol: Quote Share this post Link to post Share on other sites
The_Dude 0 Posted November 11, 2008 I'm at Oxford Brookes. I was going to change to the MEng but i'm not so sure now. The workload is quite high already and the teacher's aren't really helping at all! Think I know a few peeps at Oxford Brookes. Got no idea how big it is so don't know if its likely you'd know them. One is obsessed with his Uno Turbo. :camp: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 Finished. I really hope these lucas carriers are ok with Girling calipers! They seem to line up...blu-tac was a mofo to get out too! Did the paint solvent make the Blu-tac go all sticky :lol: :lol: :lol: It actually did! :? not the best plan I ever had but ho hum. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 I'm at Oxford Brookes. I was going to change to the MEng but i'm not so sure now. The workload is quite high already and the teacher's aren't really helping at all! Think I know a few peeps at Oxford Brookes. Got no idea how big it is so don't know if its likely you'd know them. One is obsessed with his Uno Turbo. :camp: :awesome: so when the turbo spools, it'll pull the shoddy rusted chassis apart! :clap: We had a talk last thursday night about performance aspects of cars, and how you can't just sling a set of springs on a car and expect it to handle as they ideally should be matched to the damper rates etc. Then he referenced Halfords / Ripspeed spring kits and how chavs think they're amazing when they put these on. I kid you not, one row of people sat behind me looked like this: :oops: :lol: :cry: :lol: :oops: :scratch: :oops: :confused: :pale: :oops: :mad2: :lol: :oops: It was awesome. Quote Share this post Link to post Share on other sites
pete_griff 0 Posted November 11, 2008 I'm at Oxford Brookes. I was going to change to the MEng but i'm not so sure now. The workload is quite high already and the teacher's aren't really helping at all! Think I know a few peeps at Oxford Brookes. Got no idea how big it is so don't know if its likely you'd know them. One is obsessed with his Uno Turbo. :camp: :awesome: so when the turbo spools, it'll pull the shoddy rusted chassis apart! :clap: We had a talk last thursday night about performance aspects of cars, and how you can't just sling a set of springs on a car and expect it to handle as they ideally should be matched to the damper rates etc. Then he referenced Halfords / Ripspeed spring kits and how chavs think they're amazing when they put these on. I kid you not, one row of people sat behind me looked like this: :oops: :lol: :cry: :lol: :oops: :scratch: :oops: :confused: :pale: :oops: :mad2: :lol: :oops: It was awesome.[/quote:1g3rvdk0] haha :lol: - that's brilliant about the 'candidates' behind you! - i love talking to people like that who will believe anything that the marketers tell them! i overheard a bloke in the pub a while back claim that he had a 200bhp 205 gti - it still had the 1.9 engine in, with no headwork, bottom end work, forced induction or anything - but according to him "it would eat porches for breakfast!" :lol: - you just can't write it! anyway.... tried to give you a ring ref brake lines a mintue ago - if you get in touch with me (the sooner the better) then we can sort something out. i'll be going home next around thursday and i'll be wanting to crack on with my own car as much as possible before i go back to work; but i'm sure i can spare some time to get you squared away if you let me know when you want to do it..... hope all is well anyway, wait to hear from you.... (good updates as usual!) Pete :) Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted November 11, 2008 he referenced Halfords / Ripspeed spring kits and how chavs think they're amazing when they put these on. I kid you not, one row of people sat behind me looked like this: :oops: :lol: :cry: :lol: :oops: :scratch: :oops: :confused: :pale: :oops: :mad2: :lol: :oops: It was awesome. Fantastic, I'd loved to have seen that, a video would have been ace!! :lol: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 one guy went bright bright red and we pretty much all mocked him! No idea what he drives though. Oh and the guy with the blue G60 is on my course, so I will be harassing him soon. Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted November 11, 2008 Mate, you've got so many pictures on this thread now I bet you could print them all off and make a flick book of you fixing your car! :lol: Awesome stuff though, you appear to be doing a really thorough job. :D Quote Share this post Link to post Share on other sites
was8v 0 Posted November 11, 2008 Good work - I hope you like the car once you've done all this! It will be like a new one and you'll have to keep it forever! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 haha :lol: - that's brilliant about the 'candidates' behind you! - i love talking to people like that who will believe anything that the marketers tell them! i overheard a bloke in the pub a while back claim that he had a 200bhp 205 gti - it still had the 1.9 engine in, with no headwork, bottom end work, forced induction or anything - but according to him "it would eat porches for breakfast!" :lol: - you just can't write it! anyway.... tried to give you a ring ref brake lines a mintue ago - if you get in touch with me (the sooner the better) then we can sort something out. i'll be going home next around thursday and i'll be wanting to crack on with my own car as much as possible before i go back to work; but i'm sure i can spare some time to get you squared away if you let me know when you want to do it..... hope all is well anyway, wait to hear from you.... (good updates as usual!) Pete :) Hi mate, just seen the missed call! Sorry about that. Good to chat to you though :D will be in touch about stuff on Monday. :salute: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 Mate, you've got so many pictures on this thread now I bet you could print them all off and make a flick book of you fixing your car! :lol: Awesome stuff though, you appear to be doing a really thorough job. :D Yeah... :confused: I wasn't this thorough at all with my Mk2 and i really liked that :confused4: I guess the Corrado is next-level though :nuts: (god that sound cheesy) Yeah, I have silly amounts of pictures now, probably into the hundreds :shrug:. I just tried to pop my front mount onto the spare cross member but one of the bolts was the wrong one. Hmm. VAGCAT error. Bit stuck at the mo until my springs arrive (cheers dave!) cos then I can knock up the rear struts quickly which will allow me to attach the rear beam to the car (i.e. don't want the trailing arms to trail onto the floor, hence putting suspension on) and the brakes can happen :grin: kinda annoyed though as it's real nice weather today. I don't really want to put the front up on stands too as it's a :nono: for subsequent work under the car (PAS pump reinstall and hose routing). Back to the coursework I guess then. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted November 11, 2008 :awesome: so when the turbo spools, it'll pull the shoddy rusted chassis apart! :clap: We had a talk last thursday night about performance aspects of cars, and how you can't just sling a set of springs on a car and expect it to handle as they ideally should be matched to the damper rates etc. Then he referenced Halfords / Ripspeed spring kits and how chavs think they're amazing when they put these on. I kid you not, one row of people sat behind me looked like this: :oops: :lol: :cry: :lol: :oops: :scratch: :oops: :confused: :pale: :oops: :mad2: :lol: :oops: It was awesome. ROFL...it could be them, after all most of them used to work on the Ripseed counter in Halfrauds on da Purley Way boss! I've known Uno boy (a chunky hyperactive loon called Mike)for about 3/4 years and in that time he has had the car on the road for a total of 3 months (he put it together then wrote it off and bought another shell), another is a highly racist Saffa called Pat who drives/drove a yellow MG and the another is an OK guy called Joel who drove a sh*tty Fiesta last time I saw him. Oh and maybe a highly grumpy sod of a Chelsea supporter called Matt. None of them had any decent car taste, think some of them recently clubbed together to buy a Sierra Cossy (not sure if its a genuine one, they only paid 3k for it). Fools. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 11, 2008 Well, being an ex-poly there are an awful amount of who think they're the and be all like: , and you're like.... ... Before you know it, they're braggin about their tight and how they're . So you go check out their and it seems they might have eaten some for lunch and washed it down with some cos this here ride looks like a ... The suspension's all like Engine's all like Brakes are all like Exhaust's all like It is one big and the whole thing needs to be . Please say :nono: to . Quote Share this post Link to post Share on other sites
The_Dude 0 Posted November 11, 2008 post of the year. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted November 11, 2008 DO SOME WORK! LOL! I've already said it once today but...... Funny funny man! Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted November 11, 2008 You've just ruined your flick book. Shame on you! Quote Share this post Link to post Share on other sites
pete_griff 0 Posted November 11, 2008 :lol: :lol: :lol: must point out that there's nothing at all wrong with rice however (some brilliant cars), just the 'clientelle' who drive them :? top post :D Quote Share this post Link to post Share on other sites
