J.C 10 Posted March 3, 2014 (edited) Hi all, I've been developing a backlight for the late heater controls, I'm thinking of producing an easy to fit kit which will include a pre-cut multi coloured Electroluminescence(EL) panel, Driver for EL panel and a set of instructions, Wiring is very simple, all you do is tap into the ashtray light wiring [ATTACH=CONFIG]77911[/ATTACH] Custom colours will be available on request [ATTACH=CONFIG]77912[/ATTACH] [ATTACH=CONFIG]77913[/ATTACH] Use the original green surround to locate the panel [ATTACH=CONFIG]77914[/ATTACH] Number 4 speed will be properly illuminated in production kits, [ATTACH=CONFIG]77915[/ATTACH] This panel will dim BUT it may depend on what headlight switch you've got, I've got the new one which uses a transistor to reduce the illumination Price will depend on how many orders but I expect it to be around £25 posted, So let me know what you think, cheers Steve I've been asked to put the fitting instruction on the first post, Just tried to copy/paste but didn't work, Until I figure out how to do it, The instruction are on page 9, post 85 http://the-corrado.net/showthread.php?t=85702&page=9 Steve Edited July 22, 2014 by J.C Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 3, 2014 Must say, that looks excellent! I've just done mine with EL wire which is a bit cumbersome in places so this would be ideal. May well be interested dependant on final price. Quote Share this post Link to post Share on other sites
Talltorrac 10 Posted March 3, 2014 I think I might also be interested in this - please keep me informed of price. And I hope the instructions are nice and clear - I'm a bit ham fisted when it comes to electronics!! Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted March 3, 2014 I'll take one of these when they go into production please, they look the DOGS dangly bits. Quote Share this post Link to post Share on other sites
JD Westy 10 Posted March 3, 2014 Excellent put me down for one Quote Share this post Link to post Share on other sites
kevinbowe2000 10 Posted March 3, 2014 Very interested too. Looks great. Was just about to buy some el wire to do it but yours looks so much better. The converter okay for prolonged use? Heard of then burning out with a good bit of smoke. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 3, 2014 (edited) Im in please Green outer with red and blue middle Edited March 12, 2014 by Jon_vr6 Quote Share this post Link to post Share on other sites
J.C 10 Posted March 3, 2014 Thanks for all your positive comments, I've enlarged the photos so you can get a better idea of the how even the illumination is, The rough edges will be smoothed out once the tooling is done, Steve Quote Share this post Link to post Share on other sites
n3p 3 Posted March 3, 2014 Put me down for one :) Quote Share this post Link to post Share on other sites
Ruggy 10 Posted March 3, 2014 Yep, I'm interested too mate Quote Share this post Link to post Share on other sites
J.C 10 Posted March 3, 2014 Very interested too. Looks great. Was just about to buy some el wire to do it but yours looks so much better. The converter okay for prolonged use? Heard of then burning out with a good bit of smoke. Hi Kevin I've not heard of the drivers burning out, I will do some research, I will of course replace (free of charge) any component which is faulty or not up to the job. Steve Quote Share this post Link to post Share on other sites
kevinbowe2000 10 Posted March 3, 2014 Thought I saw one person on here that had that issue or could have been another forum. Think it is to do with cheap converters, prolonged use and them getting so hot that they melt the plastic etc. Ta for the reply. Really looks great. Dam good job. Quote Share this post Link to post Share on other sites
fla 9 Posted March 3, 2014 great stuff. Would you do them in other colours, only i would want the two side dials in blue instead of green - if its not too much trouble, that is. Quote Share this post Link to post Share on other sites
J.C 10 Posted March 3, 2014 great stuff. Would you do them in other colours, only i would want the two side dials in blue instead of green - if its not too much trouble, that is. I can do them in any combination of Blue, Green and Red, any other colours there will have to be a small surcharge, additional colours are Yellow, Lime Yellow White Pink, Purple and Dark Blue Steve Quote Share this post Link to post Share on other sites
st4stokie 10 Posted March 3, 2014 That looks brilliant. Hope you start to produce them Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted March 3, 2014 I'm interested, looks like a good solution. I've used EL sheet before and have just one little concern, I found that the driver was quite noisey, you could hear it buzzing but that was a few years ago so I guess things may have moved on a bit since then. Do you know of any noise issues with these drivers? Rog. Quote Share this post Link to post Share on other sites
Micky fletch 10 Posted March 3, 2014 I could do with one buddy count me in Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted March 3, 2014 I'd be in too! Quote Share this post Link to post Share on other sites
jscVR6 0 Posted March 3, 2014 I'd definitely be up for one too. Quote Share this post Link to post Share on other sites
easypops 8 Posted March 3, 2014 Mmm purple sounds good, I'm in too, I'll confirm colour once you are up and running :) Quote Share this post Link to post Share on other sites
J.C 10 Posted March 4, 2014 I'm interested, looks like a good solution. I've used EL sheet before and have just one little concern, I found that the driver was quite noisey, you could hear it buzzing but that was a few years ago so I guess things may have moved on a bit since then. Do you know of any noise issues with these drivers? Rog. There is a slight high pitch whine, I've got very sensitive hearing and I don't notice it while driving, I can only hear it with the engine turned off, I have ordered a few different drivers (which are due to arrive in a week or so) so will pick the best(quietest) for the production kits Quote Share this post Link to post Share on other sites
jamie_300 0 Posted March 4, 2014 I'd definitely be up for a set :) Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted March 4, 2014 I'm in too, like the idea of green for the 2 outer dials and then the blue/red in the middle - Do you still need a control faceplate as may have a spare? Ian. Quote Share this post Link to post Share on other sites
matt59876 0 Posted March 4, 2014 I'm interested in a kit with red outer dials. Quote Share this post Link to post Share on other sites
