coullstar 0 Posted August 5, 2014 Okay having never had an ignition switch issue any of my previous Corrado's I may have finally had one. Drove the car to work this morning, no issue etc. In fact Iv never had a problem starting. Went out at lunch and tried to start but noticed that the dash lights did not come on however all the various relay, cliking noises were apparent as normal. Everything else is fine but car didnt even try to turn over. I replaced the ecu relay as I carry a spare but still nothing. So there I am swearing about the switch and tried to activate the alarm however nothing happened. I dont use the alarm but it always works when I hit the button by accident (Cobra original alarm). I have my spare keys so tried that fob and same. Im now in doubt as to whether its the alarm or ign switch now. Would the lack of dash ignition lights and ABS lights happen with dodgy ign switch or am I looking at alarm? Either way its stuck and going no where for the first time in my life I may be looking at not being able to fix it and get it home. Quote Share this post Link to post Share on other sites
easypops 8 Posted August 5, 2014 There is a fairly easy bypass for the switch, rules it out at worst..... I'll go and look for the link, a few wires, spade connectors are all that's needed I think Here you are http://www.the-corrado.net/showthread.php?t=3167&highlight=Ignition+bypass+Hotwire Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted August 5, 2014 Have you checked fuses as my bro had a similar problem with car not starting and turned out to be a blown fuse which was caused by the spolier motor overloading and it being on the same fuse as the stock immobiliser Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 5, 2014 Not yet, was going to do that when I get time. Thanks, Ive looked up the bypass thing already, just need to get it home then I can worry about it as have other cars to use. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 5, 2014 Fuses all okay. Im thinking alarm now. Its not triggering at all and the fob LEDs are showing there working okay. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted August 5, 2014 Looks most likely mate Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 5, 2014 Arse. I hate electrical issues with an utter passion. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 5, 2014 The alarm wouldn't stop the dash lights coming on. It would just cut the fuel and starter motor circuits and nothing else. Try wiggling the key firmly in the barrel whilst turning the key. If you get signs of life briefly, it's defo the switch. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 5, 2014 Tried that, I got very heavy handed and didnt make any difference. Its just gone from perfectly fine to nothing. I'll try bumping it and if not its flatbed time as Im not arsing about in works carpark trying to fix it. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 5, 2014 Well for the first time Im defeated. RAC on thier way....I feel a little less of man now. Quote Share this post Link to post Share on other sites
GrahamU 6 Posted August 6, 2014 Mine used to be worse on hot days, I'd have to leave the windows or doors open for a few minutes till it cooled down before it would start. I fitted a pushbutton start for those days ;) Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 6, 2014 I'm thinking ignition switch too . My T4 started doing this . Mine would start will a wiggle , I changed it before it broke down . Mabey it has just died instead of playing up first ? . Hope you get it sorted . Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted August 6, 2014 Battery flat????? Rog. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted August 6, 2014 I had this happen to me before on my last Corrado, turned out to be a bad earth between block and chassis. I seem to remember that a lot of the instruments earth through the block. Can't remember if start/run power also runs through the block or not? That earth being bad also stops the starter from working. Just my 2 cents. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 7, 2014 Thanks, will have a look when I get time. Ign switch ordered so will tyry that first. Interestingly most other items worked on the car other than the sunroof and rear spoiler and read previous posts about this but the fuse no.16 is fine. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 8, 2014 I had this happen to me before on my last Corrado, turned out to be a bad earth between block and chassis. That earth being bad also stops the starter from working. Just my 2 cents. Where is this? I got the switch out and turned it all the way as if to start the car and the relays are clicking but still the same i.e. no joy and no dash lights. All electrical items work except the sunroof and rear spoiler so must be linked. New switch on the way to try but have a feeling its not that now. Quote Share this post Link to post Share on other sites
easypops 8 Posted August 8, 2014 Did you try the bypass? My ignition switch just stopped working like yours. I also thought my starter was on the way out as it was really slow for a while, new switch cured that as well. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 8, 2014 Not yet, going to wait until new one is here first. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 13, 2014 New ignition switch and.....no joy. Exactly the same. I think its alarm related but to be honest I dont really have a clue. Im useless when it come to this so I may just rip the dash apart, remove the alarm and go from there. Situation is no lights on dash when ignition is on, immobiliser / alarm fob doesnt do anything and sunroof/rear spoiler dont work. Everything else works fine and has power. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted August 13, 2014 Unusual for the immobiliser to cut the ign power, the immobiliser circuits are normally wired so they cut the starter signal and fuel pump but I guess it depends on who fitted it. What year and model is yours, I'll have a look through the Bentley manual wiring diagrams and see if I can see anything obvious. Rog. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 13, 2014 93 vr. Thanks. What normally happens is the most of the dash lights come on when turn to position 1 of key turn. I deactivate the immobiliser and the rest of the lights come on then turn to start the car. I'm sure the alarm is as old as the car. It's a cobra one. Quote Share this post Link to post Share on other sites
Jim 2 Posted August 13, 2014 Worth just getting an auto electrician out to have a look? They should be able to diagnose it fairly quickly and maybe even bypass the alarm / immob for you? Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 13, 2014 That's probably what will happen to be honest. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted August 13, 2014 So you are getting no lights at all now then? Rog. Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 13, 2014 Nothing, not even ABS light come to think of it. Clock and odometer are showing up though. Quote Share this post Link to post Share on other sites
