Geeba
Rescued White VR!
  delfinis38 said:
Nice report... and tidy garage.. been meaning to do our garage floor for the last 30 years.
Cheers mate! ;) - it doesn't usually look that tidy :D
has anyone ever bought these kits off ebay? if so are they any good?
http://www.ebay.co.uk/itm/FEBI-SUSPENSION-UPDATE-KIT-CORRADO-VR6-GOLF-MK3-GTI-VR6-2X-ALL-ITEMS-LISTED/263045784297?_trksid=p2060778.c100290.m3507&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3De00cd84086ab4f27805d2efc628b9fe2%26pid%3D100290%26rk%3D3%26rkt%3D3%26sd%3D263008721266
Or do I get mine blasted and painted? then install something like R32 or TT bushes?
I would think Febi would be OEM?
The guy that sells them is on the Golf GTI forum. If you join and pm him, you'll get 5% off. Not a great deal but every little helps!
Yup it all helps... I only managed to squeeze 6% out of heritage this morning.
Car was looking sorry for itself when I passed it on the way to the station early yesterday morning.
Ahhh yes - it was parked up on a stand with no front end installed... my Mum isn't best pleased with the appearance, I suggested a cover, but she's not keen.
Hopefully once I can get rolling again it won't be too long before its mobile again. ;)
Have you ever purchased front suspension arms for that Corrado you're building in the loft? ;) - I cant make up my mind... blast and paint the originals and use R32 bushes or just replace the lot... hmmmm
Tell you mum it looks fine on the drive. It's quite hidden behind the gate and bushes..
No not done my suspension arms...
Personally I would get your OE Arms blasted and powder coated with R32 rear and standard front bushes - Lemforder are better quality replacements for Bushes than Febi in my opinion.
Ian.
Ian.
Cheers Ian.
I guess the R32 rears just tighten it up a bit more? does anyone know if they are still available from the dealer? Would there be any benefit to using them in the front as well? OE look and slightly stiffer? or are they too much?
  Geeba said:
Cheers Ian.
There's no voids I the R32 bushes so theres less deflection making geometry remains more stable
OK to use them up front? or will it rattle your teeth out? I had them on my MK4 Golf but unsure of them impact on the VR6.
Front right still available through Classic parts
https://www.vwheritage.com/1h0407152-wishbone-right-hand-corrado-vr6-mk3-golf
I bought a pair last year and both were about £36 iirc so the genuine one has gone up in price slightly, but still pretty good value I think considering the standard bushes are in place. I got the Mayle one advertised on heritage as well, and if I'm honest, the quality is right up there with the original. Its just as weighty, but I obviously can't tell if the bushes will last as long as the OE one.
Ian.
Right got it... when you say rear, you mean the rear-est front bush press with R32 and use the standard on the pivot bush! ;)
Out of interest has anyone tried the solid cast wishbones from an R32 or TT?
Yeah it's the rear front Wishbone bush.
I'm not sure if the R32/TT wishbones fit, but I have heard of people seam welding the standard ones so that's another option
Right wishbone bushes R32 Lemforders front/front and front/rear's, SNR wheel bearings and Pires Hubs 'check'
Still stripping the running gear and gathering parts just wondering peoples thoughts on H&R springs on standard gas shocks? my car appears to have reasonably new Sachs Gas shocks on it. but I need to sort the altitude out so was thinking H&R -30's
These look to be the same shocks at EuroCP's
http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1993/p/car-parts/suspension/suspension-and-steering/shock-absorber/?635442150&1&7b7a991fc29529ca0db07f9ae8cf19b02c373101&000925
It wasn't good on my MK4 GTI... but the standard suspension was dire on those so I did put Koni's on it in the end.
Did notice this on the H&R site...
"H&R Sport Springs are the ideal solution for the enthusiast who appreciates race-bred components designed for street use. They are suitable for use with your original dampers or will work with aftermarket sport dampers." - just wondered if people have had experience with that setup?
Edited by Geeba
Is there any preferred brand when it comes to chains and tensioners? I've seen the Euro ones are Febi? anyone know who made the originals?
I've got the H&R springs on standard shocks mate.
Car certainly looks a lot better because of this. But they needed the earlier spring caps
Sent from my SM-G900F using Tapatalk
Cheers Cressa
Still cant make my mind up on the ride/suspension yet..
One other thing I noticed when stripping my engine down is the water pump has a plastic impeller... this was a no-no on the MK4's are they let go when you least wanted it to... is this the same for the VR6?
I had a Corrado on lowering springs and standard shocks, it looked good but was a very harsh ride. Circoli brand at ECP is a metal finned water pump.
Just so people are aware - the Airtex water pump from ECP although it seems like pretty good quality also has a plastic impeller, I'm sat here holding one that turned up today... I guess I have no option but to go with that and just expect to change it in a few years... rubbish! why do they do that! :(
Well the clutch spring has turned up... not quite what I was expecting..
Can anyone tell me what I'm missing?
  Dox said:
Sorry, fat fingers, should have been 02J - its the later MK4 onwards improved shift tower on the VR6 02A gearbox, MK4 cables and shifter mounted into a Polo housing so it fits the tunnel.
Hotgolf on CGTi lightened my flywheel for £80 inc return P&P - he now trades as Gas and Gears
LUK or Sachs clutch kit
3.68 diff is what the Americans got to pep up their 2.8s (184 BHP against our 190BHP), fitted to our MK3 GTi 16V, so the diff goes in the VR6 gearbox and gives quicker acceleration and a better spread performance wise.
I have most of the above (and more) sat on shelves waiting for me to get my finger out.
Hi Dox - just a quick question... do you know roughly how much weight comes off the flywheel?
I posted it at over 10kg and weighed it on return as 6kg, the weight is machined mostly from the outer edges for less inertia
