Keyo 47 Posted May 31, 2021 Does look good with the bigger disc. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted June 1, 2021 Just read the brake part of it. I do think 288 calipers is a must and can be considered OEM+. Better brake, still same fit that's pretty good! Yes, the other components are getting old so you can't expect today's car braking but it's a simple upgrade and not really costly which is rare on a Corrado. I would upgrade to stainless hoses for I slightly better braking. Rubber hoses absorb some of the brake fluid pressure by somewhat inflating. With stainless it goes straight to the piston for maximum pressure. it's not night and day difference but I'll take anything that adds up to a better braking system. Keyo, since you like oem parts. Did the MK3 GTI in UK came with front oem red calipers? Here yes, sometimes a see sets of brand new old ones going for $400 cad = £240 Just a thought! Cheers Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted June 1, 2021 14 hours ago, Dox said: Mk4 288s are the same as late mk3 - no spacer needed as long as you use mk3 late disks. you’ll need banjo hoses either mk3 (I think mk4 are also the same?) or braided etc. If you go 312s you can only use a mk4 disk and you’ll need 6mm spacers Dox, can you educate me more about those late rotors please? Until I read your comment, I never knew or read anything about that? So early MK3 need spacers but not late? Why is that and from what year is considered late MK3? Thank you!! Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 1, 2021 19 minutes ago, ABV-VR6 said: Dox, can you educate me more about those late rotors please? Until I read your comment, I never knew or read anything about that? So early MK3 need spacers but not late? Why is that and from what year is considered late MK3? Thank you!! Early MK3 had 280mm as well so same as Corrado. Later ones had the 288mm upgrade. Think the change occurred around 95. Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 (edited) ABV Im not sure about the MK3 - its a GTI I have never owned to be honest- it is possible I suppose that the anniversary edition came with red callipers. Its true when you think about it- the VR6 is heavier then the g60 and more powerful so it is surprising VW did not upgrade the brakes to 288 mm from factory. Thanks Sean I will look on etka later and find the part numbers - be interesting to see if you can still get them new- I could then use my 280 mm from the VR to upgrade on my MK2 golf . Just out of interest if I can find a second hand set- how much does big red roughly charge for refurb. Thanks Edited June 1, 2021 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 (edited) 1 hour ago, ABV-VR6 said: Just read the brake part of it. I do think 288 calipers is a must and can be considered OEM+. Better brake, still same fit that's pretty good! Yes, the other components are getting old so you can't expect today's car braking but it's a simple upgrade and not really costly which is rare on a Corrado. I would upgrade to stainless hoses for I slightly better braking. Rubber hoses absorb some of the brake fluid pressure by somewhat inflating. With stainless it goes straight to the piston for maximum pressure. it's not night and day difference but I'll take anything that adds up to a better braking system. Keyo, since you like oem parts. Did the MK3 GTI in UK came with front oem red calipers? Here yes, sometimes a see sets of brand new old ones going for $400 cad = £240 Just a thought! Cheers Hi ABV, I can confirm the Mk3 does have an option for a 288 mm desribed as RED. NO1 on diagram. https://www.ilcats.ru/vw/?function=getParts&market=RDW&model=GO&modelcode=184&year=1997&group=6&subgroup=615&part=615040&language=en Dox/ Shaun are these correct fitment for the corrado mod ? Thanks https://www.volkswagen-classic-parts.de/en/bremssattelgehause-golf-gti-dbc664.html Its £400 for the set but would have to get carries to - works out to a fair bit so not a great option- . Edited June 1, 2021 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 (edited) Are the 288 mm factory Mk3 ones all ATE guys so I know they are genuine ? Thanks Edited June 1, 2021 by Keyo Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 1, 2021 11 minutes ago, Keyo said: Are the 288 mm factory Mk3 ones all ATE guys so I know they are genuine ? Thanks Going to say YES. 👍👍 Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2021 MK3 288mm callipers and carriers are exactly the same as MK4 288mm which are far more plentiful. I've never seen a MK4 with rusty pistons, they're up to 10 years newer and cheaper too. To fit either MK4 or MK3 to the corrado you need the MK3 288mm disks MK4 disks have a different offset and need 6mm spacers exactly the same as the 312mm do Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 (edited) 5 minutes ago, Dox said: MK3 288mm callipers and carriers are exactly the same as MK4 288mm which are far more plentiful. I've never seen a MK4 with rusty pistons, they're up to 10 years newer and cheaper too. To fit either MK4 or MK3 to the corrado you need the MK3 288mm disks MK4 disks have a different offset and need 6mm spacers exactly the same as the 312mm do Good to know. Anyone got a link to the brake hose kit you need ? Dox do the 280 mm G60 upgrade on a Mk2 16v - do i need any hose kit or is it direct fit - I know you need spacers for the BBS RA but I all ready have some fitted. Cheers Edited June 1, 2021 by Keyo Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2021 Corrado disks are 5 stud, Golf MK2 are 4 stud. You'll need the VR6 callipers and carriers, [pad - disk - pad] thickness is wider on the G60 set up than the factory 16v set up can cope with. Hoses are the same. Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 16 minutes ago, Dox said: Corrado disks are 5 stud, Golf MK2 are 4 stud. You'll need the VR6 callipers and carriers, [pad - disk - pad] thickness is wider on the G60 set up than the factory 16v set up can cope with. Hoses are the same. Thanks . Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 1, 2021 TRW BHW276E BHW275E ATE new Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 1, 2021 16 minutes ago, 1xshaunx1 said: TRW BHW276E BHW275E ATE new Oh my will have a look - thanks . Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 3, 2021 (edited) Nice set of rare NOS Ottinger alloys here - 16 x 7.5 J. 5x 100 . - good price considering they are new. https://www.ebay-kleinanzeigen.de/s-anzeige/16-oettinger-felgen-neu-5x100-golf-corrado-polo-jetta-gti-vr6/1778324251-223-1925 Edited June 3, 2021 by Keyo Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 3, 2021 Bargain. And if you had anything oettinger then they are a must have. Good find 👍 I hope someone on here buys them Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 5, 2021 Got these decals VR6 for the 288 mm brake upgrade- comes in a pack of 8 with different sizes - going with white decal and red caliper - like the uprated GTI performance pack calipers basically but with VR6 script. All in delivered £9.00 https://www.amazon.co.uk/snstyling-com-Decal-window-caliper-mirror/dp/B07NFB2H4G/ref=trb_chk_auth?dchild=1&keywords=vw+vr6+brake+caliper+decal&qid=1622890949&sr=8-1&openid.assoc_handle=amazon_checkout_gb&openid.claimed_id=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fid%2Famzn1.account.AFAMLAIWPVONXRPEWZ42VV7QLWFA&openid.identity=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fid%2Famzn1.account.AFAMLAIWPVONXRPEWZ42VV7QLWFA&openid.mode=id_res&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.op_endpoint=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fsignin&openid.response_nonce=2021-06-05T11%3A05%3A49Z1016637324497292518&openid.return_to=https%3A%2F%2Fwww.amazon.co.uk%2Fsnstyling-com-Decal-window-caliper-mirror%2Fdp%2FB07NFB2H4G%2Fref%3Dtrb_chk_auth%3Fdchild%3D1%26keywords%3Dvw%2Bvr6%2Bbrake%2Bcaliper%2Bdecal%26qid%3D1622890949%26sr%3D8-1%26trb_auth%3D1%26trb_open%3D1%26trb_bid%3Dbuy-now-button&openid.signed=assoc_handle%2Cclaimed_id%2Cidentity%2Cmode%2Cns%2Cop_endpoint%2Cresponse_nonce%2Creturn_to%2CsiteState%2Cns.pape%2Cpape.auth_policies%2Cpape.auth_time%2Csigned&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.pape.auth_policies=http%3A%2F%2Fschemas.openid.net%2Fpape%2Fpolicies%2F2007%2F06%2Fnone&openid.pape.auth_time=2021-06-05T11%3A05%3A49Z&openid.sig=wTYMwAPruVQJ3Q9Llpf4Y0TyP6Oes8qwiq7%2BaR4nkS0%3D&serial=&siteState=|hasWorkingJavascript.1 Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Is this 100 percent the correct brake lines for 288 mm upgrade as it says for rear brakes. Thanks https://www.ebay.co.uk/itm/202562895141 Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 8, 2021 Confusing as hell that post!!! Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Just now, Cressa said: Confusing as hell that post!!! Have you got a link mate for the 288 mm brake lines - cheers. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted June 8, 2021 Ya that ebay post is hard to follow. I bought a kit like this from these guys in the USA. But it looks like they only have front and rear kits with either mk3 or MK4 rears option. Not just the front ones... https://techtonicstuning.com/main/index.php?main_page=product_info&cPath=2_28_180&products_id=285&zenid=kucs1k1d8ifu4cuvevvn48sb63 Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 (edited) Cressa recently fitted 288 mm brakes - where did you get your hoses mate . The Hel advert is confusing says. front brake lines for rear disc. FRONT BRAKE LINESVOLKSWAGEN GOLF MK3 2.8 VR6 REAR DISCS / FROM CH 1H-SW560 001 (1992-1997) Thanks Edited June 8, 2021 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Do the stock 288mm golf ones fit a rado the other union correct . https://www.ebay.co.uk/itm/333984311852?hash=item4dc3042a2c:g:ZGAAAOSwiY1gjfZZ Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 8, 2021 https://auto.helperformance.com/volkswagen-golf-mk3-2-8-vr6-to-ch-1h-sw560-000-1992-1997-braided-brake-lines Try that. £45 for 2 from Hel. If the link works!!! The ones I have are goodridge phantom but came with everything else I bought Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 8, 2021 Just now, Keyo said: Do the stock 288mm golf ones fit a rado the other union correct . https://www.ebay.co.uk/itm/333984311852?hash=item4dc3042a2c:g:ZGAAAOSwiY1gjfZZ Yes Quote Share this post Link to post Share on other sites
