Keyo 47 Posted June 8, 2021 3 minutes ago, Cressa said: https://auto.helperformance.com/volkswagen-golf-mk3-2-8-vr6-to-ch-1h-sw560-000-1992-1997-braided-brake-lines Try that. £45 for 2 from Hel. If the link works!!! The ones I have are goodridge phantom but came with everything else I bought Cant see no banjo bolt round ends of that picture though Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Ok says picture is generc. Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 8, 2021 4 minutes ago, Keyo said: Cant see no banjo bolt round ends of that picture though 😂😂 I was just typing the picture info. I believe all mk3 late are the banjo Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 HEL ad states crush washers which are used with banjo fittings. if in doubt phone and order from C and R enterprises Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 (edited) Full kit from c and r on eBay https://www.ebay.co.uk/itm/110849740265 Edited June 8, 2021 by Dox Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Just now, Dox said: Full kit from c and r on eBay Link please - I do think the hel link you gave before is correct though just a typo error on hel behalf. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 1 minute ago, Keyo said: Link please - I do think the hel link you gave before is correct though just a typo error on hel behalf. Edited above Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Just out of curiosity why have people no interest in fitting the oe style rubber hose that has the correct square ending banjo. https://www.ebay.co.uk/itm/362942146476?hash=item548109a7ac:g:bAwAAOSwJepgW-Rw Quote Share this post Link to post Share on other sites
fendervg 32 Posted June 8, 2021 No issue with the OE hoses, but they tend to bulge a bit under pressure and most prefer to upgrade to braided hoses, which give a more consistent pedal feel and (maybe, but how do you measure it?) improved braking performance. Be aware that the braided hoses still use a rubber core, which can perish and split and is much harder to check than the OE ones. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 1 minute ago, fendervg said: No issue with the OE hoses, but they tend to bulge a bit under pressure and most prefer to upgrade to braided hoses, which give a more consistent pedal feel and (maybe, but how do you measure it?) improved braking performance. Be aware that the braided hoses still use a rubber core, which can perish and split and is much harder to check than the OE ones. Im going for the hel two front hoses. Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 (edited) I noticed it says on Hel 92 - 98 - thought that was odd - yours look correct there dated from 95. Edited June 8, 2021 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Some Brembo ones here. https://www.autodoc.co.uk/brembo/7549376 Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 23 minutes ago, Keyo said: Some Brembo ones here. https://www.autodoc.co.uk/brembo/7549376 Visually the pic looks to be correct, also list two bolt sizes f10 x 1 (f being fine thread) and 10 (standard metric thread), which also is correct as previously mentioned two types of thread sizes for 288mm calipers Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 2 minutes ago, Dox said: Visually the pic looks to be correct, also list two bolt sizes f10 x 1 (f being fine thread) and 10 (standard metric thread), which also is correct as previously mentioned two types of thread sizes for 288mm calipers The only thing it dont have is the bolts and copper washers. The febi set does though. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 35 minutes ago, Keyo said: The only thing it dont have is the bolts and copper washers. The febi set does though. It mentions 2 thread sizes, so I'd be surprised if they don't come complete ready to fit? Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 8, 2021 Ok I have this in the basket going off etka Mk3 288 mm VR Brake pads Brembo https://www.autodoc.co.uk/brembo/1661888 Hoses Brembo https://www.autodoc.co.uk/brembo/7549376 Discs brembo https://www.autodoc.co.uk/brembo/1657066 Hope these Mk3 oe numbers above are a direct fit to the rado. can see why not as they use the same bearing carriers i think. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2021 Hold this thought, if you chose MK4 disks and used 6mm spacers to centre the calliper over the disk you'll gain 6mm extra wheel clearance? Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 9, 2021 If you choose the mk3 route , it does all fit Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 9, 2021 (edited) Interestingly you can buy x2 callipers ATE 288 mm refurbished (come with new springs to ) for both £134.00 or TRW for similar price. Free postage (100 if you can be arsed to post your old ones to them ) Two (new) ATE carrier £ 88.00 both Slider kit and bolts both £6.00 So its the same price as sending them to Big Redd but the carriers are new- seems pointless buying a second hand set for £50.00 + refurb Big Redd £185.00 (no springs)+ postage Might just go with that instead to be honest seems lot less hassle. Autodoc sell all the above. Free postage. carries 3B0615123 Calipers left 3A0615123 right 3A0615124 https://www.autodoc.co.uk/ate/7004486 https://www.autodoc.co.uk/spares-search?keyword=OEN+3A0615124&supplier[1]=3 https://www.autodoc.co.uk/ate/7014054 https://www.autodoc.co.uk/jp-group/8879116 Edited June 9, 2021 by Keyo Quote Share this post Link to post Share on other sites
fla 9 Posted June 9, 2021 Or you could refurb them yourself. Its a nice satisfying little project and won't cost more than new seals and, if required, new pistons & slider pins and paint in your choice of colour Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 9, 2021 (edited) 21 minutes ago, fla said: Or you could refurb them yourself. Its a nice satisfying little project and won't cost more than new seals and, if required, new pistons & slider pins and paint in your choice of colour That is true Fla- I will be sending mine off to big redd but they look so damn god crusty and just wondering what proceess they use to kill the rust - Im mean the other way you get brand new ate carriers- the one bonus from Big Redd is they will come in my chosen colour red- as you say though no big deal painting some fresh silver ones red. However I have to deal with a breaker and pay postage for carriers and callipers - old carriers not nrew and will be £40.00 worse off- autodoc is the best solution if you dont own a set of 288 mm and dont have the means to diy refurb and strip the callipers and treat crusty metal. Edited June 9, 2021 by Keyo Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted June 10, 2021 Does seem mad to send them off to Big Redd at those prices. I would refurb them myself however you'd need an air compressor to push the piston out but the rest is just changing over parts. Most rust will come off with a wire bursh and you can use a dremmel or die grinder with air compresser to do the hard to reach bits. Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 10, 2021 I took mine apart and blocked the bleed and hose off with bolts. I think I removed the piston dust seal and took it my local powder coater. Popped the piston out after or maybe the powder coater did!!! Quote Share this post Link to post Share on other sites
Dox 23 Posted June 10, 2021 You can blow the pistons out with a tyre compressor or foot pump. idea for electrolysis rust removal? Quote Share this post Link to post Share on other sites
