johanson12 0 Posted October 11, 2006 Hi am new on here just bought a g60 c, in the process of havin the charger serviced an p&p. Just wonderine which is the best chip to go for as its got a 68mm pulley an a few other mods cheers mark Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 11, 2006 Go and see Jaba. Quote Share this post Link to post Share on other sites
johanson12 0 Posted October 11, 2006 will give them a call tomoro, what are them sns chips like quiet a lot of ppl on here seem to have these? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 11, 2006 Where in West Yorks are you mate? Youre best getting a SNS chip. Quote Share this post Link to post Share on other sites
johanson12 0 Posted October 11, 2006 halifax bud, ye they seem to be widely used, do g werks do the chips because my charger is there at the moment. Quote Share this post Link to post Share on other sites
flusted 0 Posted October 11, 2006 sns all the way, they have the "no digi lag" code that no other chip has which gives greatly improved response Quote Share this post Link to post Share on other sites
Craig 0 Posted October 11, 2006 ill second that, sns chip is great. many ppl have even changed over from their installed jabba chip to sns for their no lag coding! Quote Share this post Link to post Share on other sites
coolrado 0 Posted October 11, 2006 ill second that, sns chip is great. many ppl have even changed over from their installed jabba chip to sns for their no lag coding! and less overfueling which seems to be a common complaint about jabba chips. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted October 11, 2006 ill second that, sns chip is great. many ppl have even changed over from their installed jabba chip to sns for their no lag coding! and less overfueling which seems to be a common complaint about jabba chips. can defo agree with the overfuelling lol! Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted October 11, 2006 Go and see Jabba ? Uh, no.........get on to SNS tuning here: http://www.snstuning.co.uk/ And as mentioned already, get a stage 6 anti-lag chip, much better, improved throttle response, higher performance and no over-fueling. Quote Share this post Link to post Share on other sites
steveo29 0 Posted October 12, 2006 Go and see Jaba. do your self a favour and never go see jabba for anything g60 related :lol: Quote Share this post Link to post Share on other sites
Tempest 0 Posted October 12, 2006 "no digi lag" code that no other chip has Bold statement that, as I know at least one other chip maker that has overcome the Digifant lag issue :-) But would agree with the others to avoid Jabba. Jabba seem to have moved on to turboing everything. Tempest Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 12, 2006 I had a Jabba chip on my last G60, I couldn't believe the difference in power delivery and fuel consumption when I changed to an SNS. The Jabba chip had a couple of flat spots aswell, i'd certainly recomend SNS. If your charger is with G-werks at the moment, give them a call, i'm sure they'll sort you out. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted October 12, 2006 I had a Jabba chip on my last G60, I couldn't believe the difference in power delivery and fuel consumption when I changed to an SNS. The Jabba chip had a couple of flat spots aswell, i'd certainly recomend SNS. If your charger is with G-werks at the moment, give them a call, i'm sure they'll sort you out. Ditto. My Jabba chip was awful, massive over-fuelling. The SNS chip was so much better and throttle response was noticeable improved. I’d stay clear of Jabba for anything G60 related, their “stage 4” port of my charger was very average and the exhaust end bearing in the charger was the original VAG item until I had JMR open up the charger as a precaution at well over 100K miles! Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted October 12, 2006 Hi am new on here just bought a g60 c, in the process of havin the charger serviced an p&p. Just wonderine which is the best chip to go for as its got a 68mm pulley an a few other mods cheers mark You sure it isn't already chipped? with a 68mm pulley i would have thought it would be, they go hand in hand. But defo agreed sns is they way to go, gunna upgrade to that myself soon :) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 12, 2006 with a 68mm pulley i would have thought it would be, they go hand in hand EDIT: I'd agree with that, infact would not having a chip with just a pulley just feck you engine up? Quote Share this post Link to post Share on other sites
johanson12 0 Posted October 12, 2006 You sure it isn't already chipped? with a 68mm pulley i would have thought it would be, they go hand in hand. well i've just had the ecu checked an it has been chipped, but still think am gonna go for an sns chip. Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted October 12, 2006 Good work, Kind thought it would be chipped! What chip is it? Quote Share this post Link to post Share on other sites
flusted 0 Posted October 13, 2006 i removed an AMD chip from mine and added the sns and it was a big improvement Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 13, 2006 i removed an AMD chip from mine and added the sns and it was a big improvement The reason for this would of been that the AMD map would of been custom written for the car. You could bever expect a second hand chip working to its full capabilities on a car that the chip was not origailly intended for.(Unless you are very lucky ad the characteristics of the motors are idetical). Somtimes trying to save a few ££ here and there can be false econmey when buyig second hand, Espically when buying Eproms. Quote Share this post Link to post Share on other sites
