volksworld13 0 Posted February 24, 2014 I have just replaced the door membranes on my nugget g60, just wondered if anyone is keen if I initiate a group buy. Replacement membranes, and high quality butyl to the existing templates. Just a feeler if those are keen. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 24, 2014 As if by magic just been looking at replacing mine as i had a damp drivers carpet the otherday and knowing that its not heatermatrix/leak from windscreen it must be the door card membrane. With mine being a late car is the membrane just going to need holes for the wires in different areas than your G60? Price delivered and im in? Cheers Jon Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 24, 2014 Hi jon, I'm going to do my storm this weekend, so I will make a template up, and make it to a late spec membrane, will look into prices and let you know.regards alex Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 24, 2014 Cool mate, they should be the same size but as i said the holes for wires will be in different places. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 24, 2014 Yes your right, so glad I can keep the c water tight the interior is getting mouldy in this damp weather. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 24, 2014 Haha yeah, i presume your putting the clips for the bottom of the door card on top of the membrane like the original membrane? Quote Share this post Link to post Share on other sites
Ninjasean2005 10 Posted February 24, 2014 I am interested depending on price. Will it be a plain membrane, So you cut the holes you require? It might be a silly question but I am new to corrado's, is there a difference between late and early spec membranes? Apart from electric window switches? Thanks Sean Quote Share this post Link to post Share on other sites
clumpy1 11 Posted February 24, 2014 Do them yourself mate it's not hard ;) Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 24, 2014 I would be interested in these too Rob Quote Share this post Link to post Share on other sites
Mike16v 10 Posted February 24, 2014 I'd take a set... Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 24, 2014 Yes the clips go over the top of the membrane, I suppose Id be saving time to make them up, the butyl is exactly like the vw stuff, and believe me when I say once you've properly pushed it down it's down. Will keep you updated. Quote Share this post Link to post Share on other sites
fendervg 32 Posted February 24, 2014 Depending on price, I might be interested in a set for a late spec VR. What are you using to stick them on? Is it some kind of tape? Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 24, 2014 It's butyl the same stuff vw used it's a thick adhesive similar consistency to blue tak but more sticky , the original butyl would of lost it's stickiness and membranes are often damaged or ripped allowing rain water to enter into the footwells. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted February 25, 2014 (edited) Do them yourself mate it's not hard ;) Agree with Mr Clumpy. I've just done mine. Got some quality plastic membrane. and some butyl from here http://www.ebay.co.uk/itm/Butyl-Tape-Strip-Bolt-On-Panel-Sealer-Bonding-Vans-Cars-Roof-Fish-Pond-Liner-Pro-/221225330252?pt=UK_Body_Shop_Supplies_Paint&hash=item33820ea64c Edited February 25, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 25, 2014 You haven't got to use plastic membrane, Dynamat is watertight,easily trim able,and comes with its own sticky attached,and offers better sound insulation then a thin plastic sheet ! Quote Share this post Link to post Share on other sites
fla 9 Posted February 25, 2014 You haven't got to use plastic membrane, Dynamat is watertight,easily trim able,and comes with its own sticky attached,and offers better sound insulation then a thin plastic sheet ! If you need to get access to the window mech how would you go about this? Can the dynamat be removed and then stuck on again? Quote Share this post Link to post Share on other sites
clumpy1 11 Posted February 25, 2014 If you need to get access to the window mech how would you go about this? Can the dynamat be removed and then stuck on again? Good point Hasan (not saying your's is a bad idea Dragon) Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 25, 2014 I can't answer it......yet ! I haven't had to get in there yet ! lol Quote Share this post Link to post Share on other sites
Wompa 0 Posted February 25, 2014 I WANT! I just bodged together my old teared piece of membrane... I need two new! :D Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted February 25, 2014 The replacement ones from Vw are now a thin foam rather than plastic membrane Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 27, 2014 Will update thread soon with more info. Quote Share this post Link to post Share on other sites
Riley 0 Posted February 27, 2014 Possibly interested, as I was looking at getting some of the foam Vw ones. Quote Share this post Link to post Share on other sites
JAM11E 10 Posted February 27, 2014 Sign me up Quote Share this post Link to post Share on other sites
Dan_Storm 0 Posted February 28, 2014 I'm in. I've been meaning to replace my speakers, so make sense to do the membranes at the same time. Quote Share this post Link to post Share on other sites
EmGreenVR6 0 Posted February 28, 2014 Hi, Will these be cut to fit with the proper shaped bit for speaker cones? We replaced one side with a DIY job, but it's difficult to get the shape right where the membrane isn't flat. cheers, Em Quote Share this post Link to post Share on other sites
