seanl82 23 Posted September 19, 2020 On 9/19/2020 at 1:48 PM, easypops said: No mate, the gearbox came in the fire damaged car that Michael and myself bought a couple of years back, Michael took the head and the VSR, I retained the rest, the gearbox had an issue the previous owner made us aware of, 1st and 2nd difficult to select. I took it to a gearbox mechanic that I know through a friend, he repaired it and changed the 5th gear, I supplied the 5th but as Iād only ordered one half of it he supplied one šš I did ask if he could swap the lsd(wavetrac) into my working box but he said it would be better/cheaper to fix the box with it already in Thanks mate, makes sense. Can't believe how lucky you got with that fire damaged one, absolute bargain with the options it had. š Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted September 19, 2020 Very nice progress indeed! I understand your "stress" after doing so many changes, I feel the same way. You know, if you've done all of this work so far, I don't see why you couldn't figure out the issue if one present itself... Everything will get sorted out one by one. That fire damaged car sure is a real treasure, good for you! I too will be modifying my gearbox with a Wavetrac. I also sourced a R&P 3.94 and a 5th from a diesel, should make a nice combo. Keep up the good work! Cheers Quote Share this post Link to post Share on other sites
easypops 8 Posted September 19, 2020 Thanks mate, I got another few wee bits done this evening. Ecu fitted, Schrick controller wired up and vacuum pipes sorted, also thought Iād best clean the windscreen and fit a set of Lupo wipers š Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted September 19, 2020 Oh nice and so did I! I bought the last 2 Audi wiper arms in NA a few weeks ago! Not installed yet though. What size wipers did you ended up buying? I got both in 19". It looks really good on your car, can't wait to install them now! Did you keep your original caps? One of mine is cracked and the new ones are not totally the same. I've read you need to remove a washer or something? Anyway, looks really nice! Modernized oem looking. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 20, 2020 Is that a new expansion tank as well Martin? MK4 type? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 20, 2020 Iām tipping he had OE Corrado one knocking around in one of numerous full boxās of new parts. š Quote Share this post Link to post Share on other sites
Dox 28 Posted September 20, 2020 On 9/20/2020 at 8:33 AM, 1xshaunx1 said: Iām tipping he had OE Corrado one knocking around in one of numerous full boxās of new parts. š Iāve heard Heritage Obsolete Parts Dept have him on speed dial Quote Share this post Link to post Share on other sites
Cressa 45 Posted September 20, 2020 On 9/20/2020 at 9:08 AM, Dox said: Iāve heard Heritage Obsolete Parts Dept have him on speed dial Classic parts ohone number and his are the same š I'm only jealous mate , as the car is looking awesome Quote Share this post Link to post Share on other sites
easypops 8 Posted September 20, 2020 Ha ha, that made me laugh š¤£ It does happen to be a genuine Corrado reservoir šš Iād love to say where/when from but it was just there, I get the feeling it came with the last parts car but not sure š¤ Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted September 21, 2020 With my reservoir, I ended up brushing it with that creamy product hair dresser uses to color hair, it's 40% volume. You brush that on, wrap it in plastic wrap and leave it in the sun all day. It's not like new but it got 50% whiter I'll say. I'll do it again to see how white it gets... Just putting it out there as it seems there's an interest and we are not all lucky like Martin and have a new one in a box from somewhere. lol. Cheers! Quote Share this post Link to post Share on other sites
easypops 8 Posted September 21, 2020 So, great bit of progress tonight, got the brakes bled(theyāll need done again) plus the power steering bled, but most importantly, the engine is alive, idle is a bit high, MAF seems faulty as no difference when unplugged, ill swap it out soon, couple of other gremlins but Iām absolutely delighted that it runs. OBD2 conversion seems to be successful........Teves20 is yet to be confirmed but hopefully Iāll know about it once I get rolling š Quote Share this post Link to post Share on other sites
Cressa 45 Posted September 22, 2020 Great progress having a start up. Well done mate Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 22, 2020 On 9/21/2020 at 10:31 PM, easypops said: So, great bit of progress tonight, got the brakes bled(theyāll need done again) plus the power steering bled, but most importantly, the engine is alive, idle is a bit high, MAF seems faulty as no difference when unplugged, ill swap it out soon, couple of other gremlins but Iām absolutely delighted that it runs. OBD2 conversion seems to be successful........Teves20 is yet to be confirmed but hopefully Iāll know about it once I get rolling š Well done that man. Vince says that signal from maf isnāt used until the engine gets to around 75-80 degrees. Itās using cold start map. So if itās playing up and makes no difference unplugging the maf at that temp, Iād try a new one too. Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 22, 2020 Glad to hear itās up and running, itās always nervy when youāve carried out so much modification work, I know OBD2 and Teves20 are both well trodden paths but theyāre still fairly major tasks. Looking forward to seeing the next steps! Quote Share this post Link to post Share on other sites
easypops 8 Posted September 22, 2020 On 9/22/2020 at 9:28 AM, 1xshaunx1 said: Well done that man. Vince says that signal from maf isnāt used until the engine gets to around 75-80 degrees. Itās using cold start map. So if itās playing up and makes no difference unplugging the maf at that temp, Iād try a new one too. Thanks mate, great information that, Iāll hold off changing the MAF until Iām sure itās up to temperature. I do have a few spares so it wonāt be an issue to check šš Quote Share this post Link to post Share on other sites
easypops 8 Posted September 22, 2020 On 9/22/2020 at 10:50 AM, tonedef said: Glad to hear itās up and running, itās always nervy when youāve carried out so much modification work, I know OBD2 and Teves20 are both well trodden paths but theyāre still fairly major tasks. Looking forward to seeing the next steps! Thank you mate, you helped me massively with some great information and pictures, so Iām in your debt for sure. On first run of the engine the abs light has stayed on, however I remember you said Iād need to disable the airbag bulb in the switch, although again Iāll hold off until I can scan it, plus Iād like to get the wheels turning before I can be sure itās getting a signal from each corner šš Quote Share this post Link to post Share on other sites
easypops 8 Posted September 22, 2020 On 9/22/2020 at 5:23 AM, Cressa said: Great progress having a start up. Well done mate Thanks mate, I was rather nervous š¤£ Quote Share this post Link to post Share on other sites
Keyo 49 Posted September 22, 2020 On 9/22/2020 at 1:12 PM, easypops said: Thanks mate, I was rather nervous š¤£ Need to get her out now before winter arrives and have a good blast š Quote Share this post Link to post Share on other sites
easypops 8 Posted September 22, 2020 On 9/22/2020 at 4:49 PM, Keyo said: Need to get her out now before winter arrives and have a good blast š Absolutely mate šš Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 23, 2020 On 9/22/2020 at 1:11 PM, easypops said: Thank you mate, you helped me massively with some great information and pictures, so Iām in your debt for sure. On first run of the engine the abs light has stayed on, however I remember you said Iād need to disable the airbag bulb in the switch, although again Iāll hold off until I can scan it, plus Iād like to get the wheels turning before I can be sure itās getting a signal from each corner šš You're very welcome, shame I don't always know my 5 from my 8 eh??? Check if one or both lamps are lit, mine lights up on the right side at start up/ABS check. The left lamp for the airbag warning was permanently lit until I snipped it off the PCB...that fixed it! Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted September 23, 2020 What an amazing turn around mate! Very happy for you. It's a huge accomplishment and now it's just a matter of adjusting a few things and you get to enjoy it. Cheers Quote Share this post Link to post Share on other sites
easypops 8 Posted October 13, 2020 Tried a wee test fit of the fibreglass wings, they will need a little fettling but not much, Iāll need to clear the chassis of the old sealant used to bond the original wings in I think but itās difficult when you canāt get the doors open properly........looks like Iāll need to get it out of the garage š Quote Share this post Link to post Share on other sites
fla 9 Posted October 13, 2020 what a fantastic garage! Quote Share this post Link to post Share on other sites
Keyo 49 Posted October 13, 2020 They look good from where i'm sitting the line comes through spot on from the door . Help with nose heavy VR as well . Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 13, 2020 On 10/13/2020 at 1:33 PM, Keyo said: They look good from where i'm sitting the line comes through spot on from the door . Help with nose heavy VR as well . The wings don't weigh a huge amount in fairness. Bonnet, tailgate and doors on the other hand! š³ Quote Share this post Link to post Share on other sites
