easypops 8 Posted April 28, 2020 (edited) On 4/28/2020 at 11:12 AM, Keyo said: That looks in good condition- nice to see it has the original pant code sticker in place, See that black metal clip that houses the blue solenoid normally (first and second picture)- if you google that part number of that clip it does not exist on etka or not on VW Classics - so keep it safe ha. Weird that you mentioned that. I was just looking at it. The one on my car comes in 2 separate pieces, where the one on another car I have is a single piece Edited April 28, 2020 by easypops Images Quote Share this post Link to post Share on other sites
easypops 8 Posted April 28, 2020 Looking again, the back bits are the same, need to investigate the front bit Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 The bottom picture is correct I have never come across the other bracket in your hand, is there a part number on it? Quote Share this post Link to post Share on other sites
easypops 8 Posted April 28, 2020 On 4/28/2020 at 1:07 PM, Keyo said: The bottom picture is correct I have never come across the other bracket in your hand, is there a part number on it? I’ll check once I’m in(out for the daily cycle) 👍 Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 28, 2020 Great work! It's an awful job getting the factory sealer/wax off, but make it look so much cleaner when done. Looks great now Martin, keep up with the enthusiasm! Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 29, 2020 Holy what a great job once again! So you're equipped to spray paint? Yes that wax is hard to remove. What are you going to put over your new paint? I'm thinking of waxing it but is there a better sealer to keep the future grease out? Those brackets, the one underneath that goes to the right holds a part in place. The one that installs on top of the other bracket that aim towards the left hold the A/C pipe that pass there. I just removed it since I'm going to delete the A/C. I guess that would explain why some have it and some don't, depends if A/C equipped. Keep it up, you're coming with exceptional results! Quote Share this post Link to post Share on other sites
ChrisL 20 Posted April 29, 2020 Lovely job. Just checked my old photos and my blackberry corrado only has the back bracket, the front looks fabricated by someone. Quote Share this post Link to post Share on other sites
James. 9 Posted April 29, 2020 On 4/29/2020 at 7:13 AM, ChrisL said: the front looks fabricated by someone. I tend to agree, never seen one of those before (neither the VR or 8v has one either). Bracket for aftermarket cone filter? Certainly worth holding onto, should the need arise. Regarding paint. Did you use any particular paint,undercoat,primer ? I’ve had issues with paint chipping real easy. Always curious what the home sprayer uses ? Quote Share this post Link to post Share on other sites
Dox 28 Posted April 29, 2020 (edited) On 4/29/2020 at 10:08 AM, James. said: Bracket for aftermarket cone filter? I think you are correct, I had a Neuspeed bracket in the same place on my MK3 VR6 with a Cossie Ramair cone filter Edited April 29, 2020 by Dox Quote Share this post Link to post Share on other sites
easypops 8 Posted April 29, 2020 On 4/29/2020 at 10:08 AM, James. said: I tend to agree, never seen one of those before (neither the VR or 8v has one either). Bracket for aftermarket cone filter? Certainly worth holding onto, should the need arise. Regarding paint. Did you use any particular paint,undercoat,primer ? I’ve had issues with paint chipping real easy. Always curious what the home sprayer uses ? The car had a couple of questionable modifications under the bonnet, can’t actually remember but I think it did indeed have a cone type filter 👍 Paint wise, nothing special, just these Quote Share this post Link to post Share on other sites
James. 9 Posted April 29, 2020 On 4/29/2020 at 11:06 AM, easypops said: questionable modifications Care to elaborate ? Quote Share this post Link to post Share on other sites
easypops 8 Posted April 29, 2020 On 4/29/2020 at 11:15 PM, James. said: Care to elaborate ? I’ll do my best 🤣 The fpr had been bypassed, I’ll add a picture tomorrow if I can find it. It was replaced with this thing I’ve pictured. Now I’m not saying this thing is rubbish but I’m not sure it was getting used properly. When I picked the car up the seller warned me if I stalled or stopped it, it wouldn’t start for hours due to a fuel issue. Which I had to do as I needed fuel for the 150 ish mile drive home. The solution was to crank it with the fuel pipe off the rail then jam it on while it started 🤣💣. He came to the petrol station and did this procedure, fuel was squirting halfway across the courtyard 🤣. We eventually got it started by disconnecting this adjustable fpr then reconnecting it. I then drove home without stalling and next day put it back to standard. There was also some sort of filter on the vac line from the servo 🥴 Quote Share this post Link to post Share on other sites
Dox 28 Posted April 29, 2020 On 4/29/2020 at 11:37 PM, easypops said: I’ll do my best 🤣 The fpr had been bypassed, I’ll add a picture tomorrow if I can find it. It was replaced with this thing I’ve pictured. Now I’m not saying this thing is rubbish but I’m not sure it was getting used properly. When I picked the car up the seller warned me if I stalled or stopped it, it wouldn’t start for hours due to a fuel issue. Which I had to do as I needed fuel for the 150 ish mile drive home. The solution was to crank it with the fuel pipe off the rail then jam it on while it started 🤣💣. He came to the petrol station and did this procedure, fuel was squirting halfway across the courtyard 🤣. We eventually got it started by disconnecting this adjustable fpr then reconnecting it. I then drove home without stalling and next day put it back to standard. There was also some sort of filter on the vac line from the servo 🥴 That looks like an adjustable fpr? And the filter thing sounds like an Ecotec valve? Made a sucky noise? Quote Share this post Link to post Share on other sites
James. 9 Posted April 30, 2020 On 4/29/2020 at 11:37 PM, easypops said: “ fuel was squirting halfway across the courtyard “ Wow, that’s safe ! It amazes me the lengths some owners (and that goes for owners of other marques as well) will go to, with oddball repairs. When I bought the VR, under the steering wheel it had a toggle switch to disable the alarm horn. Yes, please. More if you have them. Quote Share this post Link to post Share on other sites
easypops 8 Posted May 16, 2020 Ok, quick update, I’ve been busy doing various jobs, mostly the unseen stuff. Fitted the heated seat loom, fitted the Recaro loom, fitted the servo , what a horrible thing. I couldn’t get it in but my good friend Michael (Goldie) brought the power and pushed it into place 💪🤣. All wiring is now (hopefully)done on the car, all bay wiring wrapped.Short shifter(daves16v) fitted, new sunroof seal plus retrimmed headlining fitted.Refurbished steering rack fitted to subframe and that’s fitted as well. Drivers side hub was sticky although the bearings haven’t seen any use but they were fitted a couple of years ago, swapped it out for a new hub and bearing, I’m going to do the passenger side as well. Amd just to keep it interesting, lockdown has thrown a spanner in the works a bit. My Storm that has been hiding in the body shop for the last 3 years is getting painted this weekend and will be ready next week, so, the red one needs to get out of the garage as the Storm must go in, considering it has no glass etc 🤣 Quote Share this post Link to post Share on other sites
Cressa 45 Posted May 16, 2020 I thought you must have been busy as you seemed quiet on here. All looking great, well done in getting on with it. Especially sorting the Storm 👍 Quote Share this post Link to post Share on other sites
Nmdsec 10 Posted May 16, 2020 I wondered what happened to the storm,last I remember it was going in for paint,3 years in the body shop,that’s quite some prep work,paint should be like glass 😂 Quote Share this post Link to post Share on other sites
easypops 8 Posted May 16, 2020 On 5/16/2020 at 10:13 AM, Nmdsec said: I wondered what happened to the storm,last I remember it was going in for paint,3 years in the body shop,that’s quite some prep work,paint should be like glass 😂 Ha ha, I know. They moved premises during the time they had it as they were getting busier all the time. They don’t really like doing full resprays as there is better money in repairs/quick turnarounds. They did say they would do it at the quiet times but those times just didn’t happen, until now. I can’t complain as it’s taken away a storage problem, one I now have a week to solve 🤣 Quote Share this post Link to post Share on other sites
easypops 8 Posted May 20, 2020 So, with the fairly imminent arrival of my Storm, I had to make some space. I’ve had an aqua blue breaker sitting for about 5 years , which is great if a part was required but it had to go. I wanted the rear quarter windows and a few other bits that were left on it plus Jamiehamy popped over for a bit of a socially distanced angle grinding as he needed a bit of the floor Quote Share this post Link to post Share on other sites
Cressa 45 Posted May 21, 2020 Another one off to the great Corrado Heaven 😭 Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 21, 2020 Wow, the serial hoarder letting something go, that must have been difficult for you Martin! 🤭😆 Quote Share this post Link to post Share on other sites
easypops 8 Posted May 21, 2020 Ha ha, it wasn’t easy I tell you but I knew it was over once I’d started cutting out the rear quarter windows 🤣 Quote Share this post Link to post Share on other sites
easypops 8 Posted June 9, 2020 Ok, long overdue update, lots of work on the interior at the moment, with a massive amount of help from Michael Goldie Goldsmith. Getting to the point that it’ll need to be the big ticket items going in soon, fuel tank, exhaust, engine and gearbox. This car is basically where I’m getting to put all the nice bits ( I like them anyway) I’ve bought /acquired over the years. Quote Share this post Link to post Share on other sites
tonedef 10 Posted June 9, 2020 That’s some progress, very impressed! Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 9, 2020 Has it running ? Looks like good oil pressure. Looking like a car again with lonely seats. Quote Share this post Link to post Share on other sites
