Dox 23 Posted May 23, 2023 Rear spoiler fix, Elvis used the forum to fix the speed activated spoiler (blue with white trace wire at the back of the stereo wrongly connected). Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
_Matt_ 30 Posted May 23, 2023 Watched last night, enjoyed the episode. Not sure the parts prices were realistic or the value used to "trade back" old knackered parts at £700 either. Entertainment none the less anyway. Quote Share this post Link to post Share on other sites
Dox 23 Posted May 23, 2023 For thirty years I’ve thought the supercharger worked a different way…. Quote Share this post Link to post Share on other sites
_Matt_ 30 Posted May 23, 2023 I missed that but you're probably right Dox! Quote Share this post Link to post Share on other sites
Cressa 44 Posted May 26, 2023 On 5/23/2023 at 6:08 AM, Dox said: Rear spoiler fix, Elvis used the forum to fix the speed activated spoiler (blue with white trace wire at the back of the stereo wrongly connected). Sent from my iPhone using Tapatalk Great spot , annoyed that I missed it Quote Share this post Link to post Share on other sites
fla 9 Posted May 26, 2023 Is it viewable anywhere yet? Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted May 27, 2023 11 hours ago, fla said: Is it viewable anywhere yet? Wheeler Dealers - Season 19 Episode 10 - Volkswagen Corrado G60 - YouTube Quote Share this post Link to post Share on other sites
ger040 3 Posted May 27, 2023 Who on here sorted the spoiler fix for elvis?? Quote Share this post Link to post Share on other sites
ger040 3 Posted May 27, 2023 Glad to see the g60 finally get the recognition it deserves The prices for those parts?? wow Quote Share this post Link to post Share on other sites
Cressa 44 Posted May 27, 2023 27 minutes ago, ger040 said: Who on here sorted the spoiler fix for elvis?? Dated 2013 on the screen.... this site does hold great information Quote Share this post Link to post Share on other sites
fla 9 Posted May 27, 2023 5 hours ago, Bauhaus said: Wheeler Dealers - Season 19 Episode 10 - Volkswagen Corrado G60 - YouTube Many thanks 👍🏾 Quote Share this post Link to post Share on other sites
Dox 23 Posted May 27, 2023 3 minutes ago, Dox said: No mention of the blue / white wire in the thread, I suspect John of JMR was the instigator of the fix? A bit of TV hype that might send a few more members here? Quote Share this post Link to post Share on other sites
ger040 3 Posted May 27, 2023 I must admit i did not know about about that link to the car stereo via that wire The corrado was tech advanced in its day !!! Quote Share this post Link to post Share on other sites
Dox 23 Posted May 27, 2023 Just now, ger040 said: I must admit i did not know about about that link to the car stereo via that wire The corrado was tech advanced in its day !!! In Audis it was called Gala, the radio increased volume to disguise road speed (tyre) noise - it was probably an invention of the radio manufacturers than VAG group? Quote Share this post Link to post Share on other sites
ChrisL 18 Posted May 28, 2023 I enjoyed the episode but so much they skim over. It didn’t have the side strips when they bought it and obviously changed the exhaust at some point. this forum is so valuable though, I use it loads and hope it’s never lost Quote Share this post Link to post Share on other sites
dragon green 4 Posted May 29, 2023 Talked up the rarity of the parcel shelf, but not the fog lights !Anyone notice, the VW place run by Lee, is the same place that car S.O.S. goes to Quote Share this post Link to post Share on other sites
tonedef 9 Posted May 29, 2023 Yet another one of those Karmann interiors too, I wonder how he knew because it had a G60 badge??? Quote Share this post Link to post Share on other sites
Dox 23 Posted May 29, 2023 3 hours ago, dragon green said: Talked up the rarity of the parcel shelf, but not the fog lights ! Anyone notice, the VW place run by Lee, is the same place that car S.O.S. goes to https://www.volksmagic.com/ I’m pretty sure they supplied wheeler dealers parts for their gti mk1 in the very first series? Quote Share this post Link to post Share on other sites
fendervg 32 Posted May 29, 2023 On 5/27/2023 at 4:27 PM, Dox said: In Audis it was called Gala, the radio increased volume to disguise road speed (tyre) noise - it was probably an invention of the radio manufacturers than VAG group? The blue white wire has a three way joint and provides a speed signal to the dash. spoiler control module and optionally the stereo. If the unterminated one to the steroe gets grounded or hooked up to something else it will wreak havoc. Usually the result of an aftermarket stereo being fitted, as the original harness would have had that wire tucked into the correct position in the radio ISO harness plug. I use the GALA feature all the time with my Gamma IV head unit - works a treat once you calibrate it. Quote Share this post Link to post Share on other sites
fendervg 32 Posted May 29, 2023 Haha - just watching the first bit of the video - you can see the sterring wheel jump up and down as he hits a pothole - "severely compromised" indeed. Quote Share this post Link to post Share on other sites
Dox 23 Posted May 29, 2023 (edited) 18 minutes ago, fendervg said: The blue white wire has a three way joint and provides a speed signal to the dash. spoiler control module and optionally the stereo. If the unterminated one to the steroe gets grounded or hooked up to something else it will wreak havoc. Usually the result of an aftermarket stereo being fitted, as the original harness would have had that wire tucked into the correct position in the radio ISO harness plug. I use the GALA feature all the time with my Gamma IV head unit - works a treat once you calibrate it. One of the first things I did with my car was to remove the Sony screech / vibrate box - who needs one when you have the joy of narrow angle six? Edited May 29, 2023 by Dox Quote Share this post Link to post Share on other sites
Les Day 0 Posted yesterday at 07:08 PM Hi just enjoyed the program apart from the test drive at the end, how did the gentleman that bought this car drive this manual car with one arm without disabled adaption ? Quote Share this post Link to post Share on other sites
