Jim
The "what I did to my Corrado today" thread...
i fitted all new poly bushes,top mounts ,coilovers,drop links ect.but when taking off the rear axle i snapped a couple of hard brake lines :( so ordered a nickle pipe set to make all new ones :D (now rado is sat at works farm unusable) :(
Started fitting the new earth strap for the bonnet. The nut on the bonnet is well and truely stuck so covered in wd40 over night!
!st time on this thread, i have just fitted some merc wheels, need a 20mm adapter to get the 112 to 100 pcd. they look really good, fitting some coilovers tommorow
As requested, pics of flocked dash in and scooby seats fitted :salute:
Do you find it hard to resist stroking the dash? lol
I didn't fit new brake pads... they were less than 1/2 used...
I did replace the heater thermal fuse though...
Marc
I opened the garage, looked at it sadly sat there gathering dust, gave it a pat, sighed and closed the door again as I have done for some time :salute:
Took my door apart, cleaned and greased handles, locks, window runner ,fitted new window rollers too. The door handles have never felt this good in 6 years of ownership! I assumed they were sh4gged! Well worth it!
Not driven the car for 2 weeks..recharged battery and took car out for a chill out drive :D
busy day
changed headlights back to tinted originals instead of black angel eyes my rado came with.
fitted new debadged grill.
fitted the headlining id covered in black alcantara.
changed the wheels to bbs instead of audi winters as need to sell the winters to raise funds for respray.
tomorrow is big clean day!
couldn't get the front carriers off
They are really tight !!!! I took mine to a local exhaust fitter to have them loosened then retightened just enough for me to get home to work on them.
Used a big home made breaker bar when i did mine they are prone to rounding off so be careful
how do you get a bar on there?
Turn the wheels to give you the angle you need
that's a good point :salute:
