ABV-VR6 12 Posted April 27, 2020 Absolutely mate! This is worth gold... You're lucky to be in that position. The mechanic I had here who specializes in VW decided to close the shop after 20 years, he's moving back to Germany. I was pretty sad when he told me and now I can only rely on myself, YouTube and you guys on the forum. If you get more pictures, please show us! Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 27, 2020 25 minutes ago, ABV-VR6 said: Absolutely mate! This is worth gold... You're lucky to be in that position. The mechanic I had here who specializes in VW decided to close the shop after 20 years, he's moving back to Germany. I was pretty sad when he told me and now I can only rely on myself, YouTube and you guys on the forum. If you get more pictures, please show us! To be fair though you will learn a hell of lot doing it your way. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 27, 2020 That's true. Good positive point, thank you! As long as I don't make too many costly mistake ha! Cheers Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 (edited) Went for a stock look on the Schrick - she is nearly ready to go back in the bay. Pictures attached. Edited April 28, 2020 by Keyo Quote Share this post Link to post Share on other sites
easypops 8 Posted April 28, 2020 Looks absolutely magic 😎 Quote Share this post Link to post Share on other sites
Cressa 46 Posted April 28, 2020 34 minutes ago, Keyo said: Went for a stock look on the Schrick - she is nearly ready to go back in the bay. Pictures attached. Looks absolutely gorgeous. Just glad I'm not paying for it. Stock looks good 👍 Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 1 minute ago, Cressa said: Looks absolutely gorgeous. Just glad I'm not paying for it. Stock looks good 👍 Thanks Cressa much appreciated. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 22 minutes ago, easypops said: Looks absolutely magic 😎 Thanks EP. Quote Share this post Link to post Share on other sites
James. 9 Posted April 28, 2020 (edited) Stock’s the way to go. Will you have to modify the bonnet ? Edited April 28, 2020 by James. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 (edited) 1 hour ago, James. said: Stock’s the way to go. Will you have to modify the bonnet ? All ready a cut on the underside of the bonnet when it was fitted in the car in 2003 - you can also see on the left front corner some chaffing from the bonnet when some new engine mounts were fitted and raised the engine a little. Edited April 28, 2020 by Keyo Quote Share this post Link to post Share on other sites
James. 9 Posted April 28, 2020 I see. Shame you can’t shorten the mounts to reduce the overall height of the block. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 28, 2020 (edited) 8 minutes ago, James. said: I see. Shame you can’t shorten the mounts to reduce the overall height of the block. It had a Vibratechnic mount on before and that sat a little lower I guess - prob a mistake swapping it out for a stock one but I wanted to experience the ride on stock mounts- going to cut a little more away and have some paint with correct code and tidy it up- just one of those slight issues as the Schrick was designed for a Mk3 bay I believe. I imagine the VSR no under cutting needed on the bonnett ? Edited April 28, 2020 by Keyo Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 28, 2020 Stock... It's a Schrick! Lol Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 29, 2020 Yeah, I'm not sure about the Schrick mate... I think you should sell it to me 😉 Seriously, it's a real beauty! It's such a nice piece, I'm almost jealous! Color combo is classic, I love the setup specially on your black car. Looking at your engine, I see the OEM plastic crack pipe and thermostat housing. No problem with them? I'm asking because I was thinking of upgrading to the Grüvenparts setup. Can't wait to see that engine in the car! Cheers Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 29, 2020 Gruvenparts ones are nice to have, but not cheap - especially the thermostat housing. If you have the money you could put them on for peace of mind - but to be honest the original items last well over 20 years and at least 100k miles, so if you change them for new ones now you should be good for another long stretch. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 29, 2020 (edited) Engine so what failed that lead to a rebuild ? So attached is three valves that are slightly bent (can't tell off picture) - if you put the end in a drill and pressed the button each one will shake all over the place This would of led to at least 40 percent less power in each cylinder affected due to lack of compression. The valve guides were also off shape- valve seals no good- and were way past good- the cylinders had slight ovulation. What I will say anyone with a engine that has covered 150k and thinks that just changing the valve seals is a fix to smokey exhaust dream on -. The head was in perfect condition. The last owner had a firm called John Austin VW Specialist in Colchester do the timing chain in 2018 only about 6k miles ago- charged £1,620.00 have receipt. Inspection of there work after removal of the timing chain trim was reported as very poor and incorrect- so I would look else where if your in that part of the country, make your way to a specialist like Stealth instead. Edited April 29, 2020 by Keyo Quote Share this post Link to post Share on other sites
Dox 31 Posted April 29, 2020 Rolling them on a flat surface should show up any distortion Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 4, 2020 Black magic finally returns home. Many thanks Vince ! Even though I have owned a VR for a few years today was the first ever day i really found out what it was all about. The engine was a completely different beast even though I couldn't go past 3500 revs because of bedding in. Cannot thank Vince enough, the engine was down on power before because of the bent valves causing low compression, but now with the Schick ecu chip from Vince and new cylinders and pistons she is a different creature- the dynamics and performance on the car are on an another level. Attached a few photos of her back in the bay and bedding procedure. Please note we all have a different take on bedding in a new engine but what you have to remember is VW have multi million pound precise machinery and constant heat at 20 degrees - so you need to go gentle on a rebuilt engine that has been honed aftermarket as per Stealth advice. Quote Share this post Link to post Share on other sites
Cressa 46 Posted May 4, 2020 Very very nice mate. Enjoy cruising as you bed her in 👍 Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 4, 2020 1 minute ago, Cressa said: Very very nice mate. Enjoy cruising as you bed her in 👍 Thanks Cressa youll be there soon mate its worth the pain , agony and empty pockets + you have aircon grrr ! Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 4, 2020 Congrats on getting it back! I'm sure it'll be difficult trying to resist temptation in putting your foot down, but a good excuse to drive her as much as possible. 👍 Quote Share this post Link to post Share on other sites
tonedef 10 Posted May 4, 2020 That’s looking good in there, only seems like yesterday it was on Vince’s engine stand. Enjoy getting it bedded in, essential journeys only of course! Quote Share this post Link to post Share on other sites
ger040 4 Posted May 4, 2020 car looks amazing keyo - best of luck with it pity the schrick is hidden below the bonnet and no one can see it! i have to say also the red vr6 badge is much better than the silver cant help but be really be drawn to it Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 4, 2020 (edited) 56 minutes ago, seanl82 said: Congrats on getting it back! I'm sure it'll be difficult trying to resist temptation in putting your foot down, but a good excuse to drive her as much as possible. 👍 Thanks mate -You got it in one Sean very hard to hold back on the throttle its like Adam eating the apple 19 minutes ago, ger040 said: car looks amazing keyo - best of luck with it pity the schrick is hidden below the bonnet and no one can see it! i have to say also the red vr6 badge is much better than the silver cant help but be really be drawn to it Thanks Geri and sorry chap I will get some better photos tomorrow looking downwards - car was parked nose up a hill so i could get the sun reflecting off the schrick . . Well they do say red in the animal kingdom is for danger and the VR can be snappy little sh.. when it wants to be ! If you want chap I can give you a link for any badges the price on them have come to more like £40.00 and less just let me know. 35 minutes ago, tonedef said: That’s looking good in there, only seems like yesterday it was on Vince’s engine stand. Enjoy getting it bedded in, essential journeys only of course! Thanks TD Im actually looking for a courier job to Scotland for the next two weeks ha ! Edited May 4, 2020 by Keyo Quote Share this post Link to post Share on other sites
tonedef 10 Posted May 4, 2020 14 minutes ago, Keyo said: Thanks TD Im actually looking for a courier job to Scotland for the next two weeks ha ! Parts collection and delivery for easypops? Quote Share this post Link to post Share on other sites
