stormseeker
VAG-COM scanning & help
Best money I ever spent on car tools! So useful! Oh btw, I'm in South Central Lincolnshire if anyone needs their cars looking at. Bring it to me and ill scan for free.
Hi, got a '92 vr6 with the 2x2 connectors, ordered a 2x2 to OBD adaptor cable but whats the best recommendation for software that will talk to it? Cheers
Not sure if anyone is updating the list in the 1st page but I've now got VCDS and I'm happy to help anyone in the Cambridgeshire/surrounding area, plus if anyone wants me to bring it along to meets or shows etc I'm going to just let me know.
I've just bagged myself a diagnostic scanner,
it's the VGATE VS450 scanner,
it's purely for VW's and Audi's from 1990 to 2009,
but says it may do newer models as well.
I used it on my Corrado today as my ABS light came on,
scanner said it was the O/S/F ABS sensor,
so cleared the fault code and it's been ok so far,
but may still have to purchase a new sensor,
if it's on the way out.
But anyway if anyone needs any help,
in the Bournemouth / Hampshire area,
I've now got a scanner,
with both leads 16 pin OBD2 and 2x2 data link lead.
The 2x2 lead only works with this scanner,
if there's 4 wires connected to the black & white plugs,
if there's only 3 wires connected it may not work on your vehicle.
Si
Anyone near Swansea with vagcom? I think ours may be using too much fuel, wondering if there's any faults that need sorting before she gets remapped.
hi im based just outside cardiff south wales ive got vcds 14.10 with 16pin an 2+2 adapter.just been scanning a corrado i bought for my dad its 95 2.0 auto with the ady motor and vag com does read the motor on that 1.if anyone needs any help get in touch.
Need Vagcom also in lancs northwest preston,bolton.manchester ANYONEEEEEE :shrug: help needed
Did you get sorted?
Anyone around Preston could help me with Vag Com? Thanks.
Hi,
Anybody near Canterbury that could scan my VR6, my ABS light is on and i want to see if its a sensor or pump issue. Thanks Jon
If no one else closer is able to then that'll be fine! Do you have vcds? I have used a generic scanning tool on it
Sent from my iPad using Tapatalk
Yeah, I do mate.
Hi, I have just swap gearbox from auto to manual in my 1994 VR6. Does not start.
I think that ECU still thinking it's an AUTO>???
What can I do ? will VCDS Lite help?
- I heard that ECU need to be re-map to know that its on manual.
- or do I need to just unplug the Auto box ECU?
Thanks
Hi Everyone, I've got a '95 vr6 Auto, would the diagnostics plug still be located under gearlever or elsewhere, could someone please clarify
Thanks
Thanks
Just pop it off and have a look mate. Takes seconds.
Thanks
Yes
